Can you use Fusion 360 CAM on a Prototrak CNC Mill or Lathe?
Likes Likes:  0
Results 1 to 7 of 7
    Feb 2007
    Virginia
    148
    6
    9
    Default Can you use Fusion 360 CAM on a Prototrak CNC Mill or Lathe?
    Hello Forum,
    I am wondering whether you can use Fusion 360 generated G-code on a ProtoTrak CNC Mill or Lathe.
    I went to the ProtoTrak web site could not not easily find any idea as to whether there is a
    way to load G-code or is it all conversational?
    Thank you,
    Cismontguy
    Nov 2010
    UNITED KINGDOM
    58
    13
    8
    Here is the list of all the Autodesk CAM posts
    Post Library for Fusion 360 and Autodesk HSM | Autodesk HSM
    Not much use on the control side but it can produce code apparently ( and I had it bookmarked )
    Feb 2007
    Virginia
    148
    6
    9
    Ok, Thank you for the link. I should have thought about looking at Fusion 360
    rather than ProtoTrak?
    Cismontguy
    Mar 2016
    Georgia
    62
    16
    Speak to Joseph in tech support, he can answer you questions.Depending on year model , it will most likely take a Fanuc 6T or 6M post to run code.
    May 2007
    Mocksville, NC
    104
    Quote Originally Posted by Cismontguy View Post
    Hello Forum,
    Thank you,
    Cismontguy
    Yes you can, do it almost daily here. Depending on what control your Trak machine has determines what post to use. I have one post for my AGE3 machine, another one for same but written for the add on DNC function, and a third that puts out code for my KMX machine that uses .GCD file extensions. Any control after the AGE3 can read and execute full 3 axis G-code files. AGE3 and earlier can read G-code but only run in 2 1/2 axis and file size is limited. You need a special no longer available dongle for full 3 axis movement and unlimited file length with that and earlier controls.
    Aug 2018
    You can still find the DNC key but not through Southwest Industries. I bought one about 2 months ago from Marco Muralles (401-952-4022). I can now run full 3 axis on our 2001 Trak QuikCell, just had to change the post processor in Fusion to output DNC files. It seems to be working with no problems. I believe Marco said he had several DNC keys available.
    Feb 2007
    Virginia
    148
    6
    9
    Thanks for the reply and helpful information. I hope others will find it useful too. Unfortunately
    for me, I think this project has gone to someone else as I have not heard back from the company that
    I was trying to work with. Cismontguy.
