Can you use Fusion 360 CAM on a Prototrak CNC Mill or Lathe?
Cismontguy
Feb 28, 2007
Earlysville, VA
Hello Forum,
I am wondering whether you can use Fusion 360 generated G-code on a ProtoTrak CNC Mill or Lathe.
I went to the ProtoTrak web site could not not easily find any idea as to whether there is a
way to load G-code or is it all conversational?
Thank you,
Cismontguy
Speak to Joseph in tech support, he can answer you questions.Depending on year model , it will most likely take a Fanuc 6T or 6M post to run code.
Hello Forum,
Thank you,
Cismontguy
Yes you can, do it almost daily here. Depending on what control your Trak machine has determines what post to use. I have one post for my AGE3 machine, another one for same but written for the add on DNC function, and a third that puts out code for my KMX machine that uses .GCD file extensions. Any control after the AGE3 can read and execute full 3 axis G-code files. AGE3 and earlier can read G-code but only run in 2 1/2 axis and file size is limited. You need a special no longer available dongle for full 3 axis movement and unlimited file length with that and earlier controls.
You can still find the DNC key but not through Southwest Industries. I bought one about 2 months ago from Marco Muralles (401-952-4022). I can now run full 3 axis on our 2001 Trak QuikCell, just had to change the post processor in Fusion to output DNC files. It seems to be working with no problems. I believe Marco said he had several DNC keys available.
Thanks for the reply and helpful information. I hope others will find it useful too. Unfortunately
for me, I think this project has gone to someone else as I have not heard back from the company that
I was trying to work with. Cismontguy.
An old post, but I was wondering if you could tell me more about your quick cell. I have the exact same setup now with DNC and was wondering which post processor you use.
Sorry, I didn't see your post until now.
I'm using the Proto TRAK GCD post processor. I modified it to output as a .DNC extension rather than GCD.
Let me know if you have any other questions. I'm far from an expert but will help if I can.
Question about prototrak lathes. I'm working on a RLX and importing .CAM files. Every time I load a new program (or an adjusted one) I have to reassign the tools (tool 1 is offset 162 fe). Is there a way to automate this? I can make the Fusion post generate tool codes.
