Changing multiple holes sizes of same diameter at same time using MCX 6
Results 1 to 9 of 9
    Aug 2006
    covina, ca
    270
    Default Changing multiple holes sizes of same diameter at same time using MCX 6
    I have about 20 different files with hundreds of .0625" hole geometry and I need to change all of those holes to .125" diameter. Is there a way to change all of them in one shot? It would take 15 hours to change them all individually. I have tried using the select all button and I put in the correct diameter to select all of the holes. But when I use the anaylze button to change them I have to do each one individually. Please help. I do not have 15 hours to spend changing all of these hole sizes.
  2. Likes DannyBobandy liked this post
  3. #2
    Mar 2011
    Clearwater FLA
    1,115
    76
    213
    Is there a reason why you are changing the design? I am sure you can pick the arcs and tell MC to drill the holes with any size tool you want...
    Oct 2006
    Boston,Mass.
    1,973
    69
    163
    Just change the speed and feed and set-up sheet for the new drill size...Use the same programs...
    Aug 2007
    Northern Utah
    423
    83
    98
    There is a chook to do this that you can download from CNC Software's website. go to mastercam.com and in their download section look for "Arc MultiEdit". There is a version/patch for X6. slick and easy to use
  6. Likes Mtndew liked this post
  7. #5
    Aug 2006
    covina, ca
    270
    The reason I have to change the holes sizes is because they are .dx files for a laser cutting program. Forgot to mention that. I will the multiedit. Thank you.
  8. #6
    May 2005
    Vancouver, WA
    465
    18
    You could also try offset contour and box chain all the circles (set a mask if you need to).
  9. #7
    Mar 2011
    Clearwater FLA
    1,115
    76
    213
    CPT Crunch,
    That's what I was thinking, or just leaving stock for finish ...
  10. #8
    Aug 2006
    covina, ca
    270
    Arc multi edit worked like a champ .. Thank you
  11. Likes Mtndew liked this post
  12. #9
    Dec 2017
    Wisconsin
    I just ran into this same situation today and I agree the ArcMultiEdit Add-In worked great!
