CNC Machine Simulation Software
Likes Likes:  0
Results 1 to 8 of 8
    Aug 2009
    FL
    71
    Default CNC Machine Simulation Software
    So i'm looking at getting a g-code machine simulation software to add to my line up. I have included in my list Vericut, NCSIMUL, Eureka and CIMCO. I need it to work on both mills & lathes. I need the ability to make my own machines and control files.
    Any others I should look at?
    Jan 2019
    87
    8
    Are you wanting a software that goes beyond what most cam packages produce(simulation wise)?
    I've heard hype of CAMplete, if so.
    Sent from my SM-G955U using Tapatalk
    Aug 2009
    FL
    71
    Quote Originally Posted by sirAIG View Post
    Yes, I want something that actually simulates g-code, most CAM software are reading their on internal CLS file. If your using special macros, custom G or M codes, then it is normally not simulated. I also, do a fair amount revisions to legacy NC programs with no CAM available at all. The goal is to allow me to validate NC programs off-line more accurately with g-code simulation. BTW, I always use my CAM package simulation module prior to posting.
    I will add CAMplete to the list, I forgot about that one.
    Sep 2013
    Minnesota
    318
    107
    72
    Quote Originally Posted by Mfg_Engineer View Post
    Some software such as NX gives you the option to simulate the internal operation, the internal operation output from a specific post processor (super nice) or lastly an NC file. You didn't mention what you're using; are you sure your cam software cannot simulate the way you want? If not my vote goes for an external solution goes for Vericut.
    Feb 2006
    so cal, usa
    673
    262
    175
    I think CNC Cookbook makes what you're asking about, and the support is excellent!
    Aug 2006
    Wisconsin
    1,679
    763
    755
    Keep in mind CAMPlete does not simulate YOUR g-code, it creates it's own with your cut file and own post processor.
    Sep 2017
    Wisconsin
    979
    223
    628
    Plus, as much of a CAMplete fanboi as I am, I don't think you can make your own machine definitions in it. Give Jeff up there a call and ask but I think it is licensed on a per-machine basis. It is designed to be turn key, not really what it sounds like you want.
    Feb 2006
    Ontario, Canada
    828
    36
    111
    Take a look at Eureka as well.
    CNC simulation software | NC and G code simulator, robot programming
    If this interests you, contact Lemoine Technologies, as they are a reseller, but they also have an app that pretty much automates the entire process. We use it on our cells for lights out machining. The support is exceptional.
