CNC Router Software
Likes Likes:  0
Results 1 to 13 of 13
    Dec 2012
    IA, USA
    51
    5
    Default CNC Router Software
    I am looking for suggestions on some new CAM software for our wood routers. We currently use Alphacam, which is fine but can be a bit clunky at times. It needs to be powerful nesting software. Most programs are made off of 2D drawings, but being able to work with Solidworks would be beneficial. This is not some BS X-Carve router. We turn out close to $600Mil/yea. I'm after something that can possibly integrate with ERP software and bring work orders in based on color, quantity, date, etc.
    If anyone knows of any advanced software like this, I'd love to hear about it.
    ~RPM
    Dec 2008
    Arizona
    1,748
    178
    223
    Cabinet Vision from Hexagon
    Jun 2012
    Michigan
    5,196
    4770
    3146
    I know Mastercam has a Router package, but I know absolutely nothing about it.
    May 2014
    Los Angeles
    457
    83
    Quote Originally Posted by Mtndew View Post
    It's pretty good. Nesting and the like is all there so is onion skining. Sigma nest seems good too. If nesting is not necessary then almost any cam system should be fine.
    Mar 2006
    PHILIPPINES
    2,671
    695
    1044
    You are knocking down $600 mil a year with a router and want to change things????? Um, ok
    I've used Solidworks with nesting works and Powermill for routers with no problem. I'm not sure about the integration but cranking out that much money you should have no problem getting a custom ERP made to work with the software.
    Apr 2018
    4,193
    1896
    Quote Originally Posted by g-coder05 View Post
    Sandy used to explain how programs for wood routing had to be different than metal ... since he mentioned Alphacam, that came to mind.
    On your point number one, agreed. Don't mess with something that works
    Sep 2013
    Minnesota
    318
    107
    72
    So far I don't think any mid range cad cam application will integrate with ERP that way you've mentioned but I may be wrong. Higher tier like NX can access api functions via C and Vb and I know there is bidirectional control with external applications and perhaps the others like Creo or Catia. You can assign attributes to various modeling aspects which may be what you're looking for. Aside from assigning model attributes on dumb models from customers for feature based machining I haven't had the need for deeper functionality as you described.
    If no other NX people chime in here and you want to delve deeper into how NX can do it you might try posting in the NX forum at the Eng-Tips.com site.
    Oct 2011
    Michigan
    139
    13
    47
    Efficient nesting and interfacing with ERP systems is pretty much what the TruNest program that Autodesk bought a few years back did, it is mostly used in large scale fabrication, not small shops because integration is quite involved. I'm not sure about using a router though, I think it was geared more towards plasma, laser, water jet fabrication.
    Jan 2003
    Temple, Texas
    2,372
    15
    239
    I use VusualCAD/CAM for my router. Parts are done in Solidwords. VCC does nesting and CAM. That said, to do nesting well - you have to learn the program. I would not describe the nesting as powerful. They will give you a free demo of flattening a Solidworks Assembly, Nesting and CAM.
    Sep 2010
    Vancouver Canada
    976
    741
    364
    MasterCAM has a serious API which could probably be integrated with anything and be optimized for routing to make ERP to CAM pretty swift. I visited Vorum industries recently, who sells software and machines to shape foam mostly for wheelchair seats and prosthetics. The MasterCAM integration is with their 3D scanning and outputting to their foam cutting machinery is amazing. It's a totally different application but sold me on the notion that there's a whole lot of power in MasterCAM people don't (can't without advanced skills!) take advantage of.
  11. #11
    May 2020
    Alphacam Router has many pros:
    • Aggregate Support
    • Planar Machining
    • 3D Engraving
    • 3D Routing
    • Geometry Constraint Manager
    • Drilling Unit
    • and of course, integrated CAD CAM
  12. #12
    May 2019
    Michigan
    1,437
    401
    641
    Quote Originally Posted by barban View Post
    • Aggregate Support
    • Planar Machining
    • 3D Engraving
    • 3D Routing
    • Drilling Unit
    Ummm... Ok, great!!
    Can I have 3 seats?
  13. #13
    Jan 2007
    Central Jersey
    21
    Hey, perhaps you get the router with it...
