Creating tool paths with 3D lathe part drawn in SolidWorks
Results 1 to 6 of 6
    Jun 2017
    CANADA
    British Columbia
    7
    Question Creating tool paths with 3D lathe part drawn in SolidWorks
    Hey guys!
    I've done this before but I have totally forgotten how to do it. Basically I have a part I drew in solidworks that I've made from 2D to 3D, and imported it into mastercam. Now the issue is I can't select tool path lines because the drawing is in 3D.
    Now I've done this before, but I've forgotten how but I was able to generate 2D tool path line's in mastercam. Any clue what I was doing back then? Thanks in advance.
    EDIT:
    It is a lathe part.
    EDIT 2:
    Found solution thanks!
    Jul 2008
    Ontario, Canada
    248
    5
    83
    Are you going to leave us all in suspense? What was your solution?
    Apr 2006
    Ga.
    118
    Cool
    The 2 ways I would handle it would be solid chaining or do a turn profile and create the top profile and save the wireframe to a separate level and chain the wireframe. I like the turn profile the best because I can change the wire frame if need be a lot easier to get the path I would need. Turn profile-slice-upper profile works best, you get very clean wireframe to work with. That's the thing I really love about Mastercam, so many ways to get the job done. Just choose the one that works best for you and get really good at it and you'll look like a superstar!!
    Dec 2008
    Arizona
    1,640
    138
    182
    In SW only revolve it 180 degrees or if you used extrusion and other features cut it in half then when you bring into a CAM software you get the profiles, do this for surfcam traditional.
    Jan 2015
    516
    80
    261
    Quote Originally Posted by len_1962 View Post
    Or create spline, part line.
    Never used MC, but I'd think it would have a similar function? Even Smurfcam can do it.
    Dec 2008
    Arizona
    1,640
    138
    182
    Quote Originally Posted by thesidetalker View Post
    so much easier with SW, hell you can even make up a bunch of configs of the part and surfcam will bring those in on different layers.
