Delcam Powershape
Likes Likes:  0
Results 1 to 3 of 3
    Feb 2008
    Mishawaka, IN
    361
    41
    87
    Default Delcam Powershape
    Learning Powershape and making progress; but not without issue:
    For example, I make a 20x20 box and convert it to composite curve, then I smart surface it and get what looks like a great surface all flat in multiple orientations.
    But, then I convert it to a solid and run the solid doctor then it says there is a hole in one corner. If I automatically fix this non visible hole-- then additional problem of overlapping surfaces comes up. Whats up with this hole? I think I can flip a switch to ignore it-- it says it would effect a Boolean operation.
    Anyone have insight?
    Nov 2010
    north carolina usa
    135
    21
    27
    Since it is a solid from a single surface; an open solid and not closed, I would ignore the intentional large hole.
    Feb 2008
    Mishawaka, IN
    361
    41
    87
    Default Solid to Surface worked when created in Powershape(instead of surfaces only)
    Quote Originally Posted by jelrod1 View Post
    I decided to build part in a solid first this time in Powershape and then convert it to surfaces. This yielded a problem free surface model.
    I designed another part in Inventor with some contours and sweeps that showed up fine within Inventor... But when I brought it into Powershape-- there were several holes and overlapping surfaces using the doctor... So I am now going to rebuild the model in Powershape and see if I get a better result.
