Expanded metal in solidworks?
Results 1 to 10 of 10
    Apr 2007
    Dublin Texas
    2,589
    1408
    914
    Default Expanded metal in solidworks?
    I've ran through youtube and know that I can change the appearance of a surface, but is there a way to generate expanded metal without linear cut patterns? I was playing with weldments and was wondering if it had some sort of expanded metal generator but couldn't find anything.
    Thanks in advance
    i_r_
    Oct 2010
    Oregon
    4,972
    4086
    1789
    Flattened expanded metal will be a lot easier than non-flattened. Array a diamond shape over a sheet and use the array to punch holes. Obviously creates a whole lot more geometry than applying a surface shader/finish with alpha/transparency.
    Jan 2016
    New Jersey
    191
    62
    80
    From the standpoint of systems resources (especially in the context of larger assemblies), I would generally suggest changing the appearance rather than modeling the 3D geometry. There may be an expanded metal appearance option in Solidworks I'm not already aware of, but you can always grab an image from the internet and apply it to a face. If you're using it for engineering purposes, don't forget to create an expanded metal material to get the correct density.
    Feb 2013
    Idaho
    591
    124
    656
    There is a couple on grabcad. I had to use it on a project (fea) and it drastically hurts your rebuild time.
    Apr 2015
    AUSTRALIA
    557
    33
    130
    The sheetmetal area lets you fold and unfold etc to give shapes both in folded state and unfolded state, just learning it now.
    Have not seen any expanded metal function i suspect you would need to investigate if you can model a small part then do a array to get more of it without having to draw it multiple times.
    Oct 2014
    Ohio
    180
    711
    40
    LMGTFY Expanded mesh/expanded metal | SOLIDWORKS Forums
    Alternatively, under Appearances > Steel, there is a Chain Link Steel option. Take a look at the advanced appearance properties, you may be able to create a custom appearance.
    Aug 2011
    NE Wyoming
    55
    24
    Quote Originally Posted by mountie View Post
    This is the best way to do it.
    Apr 2007
    Dublin Texas
    2,589
    1408
    914
    If I try to punch holes with a linear pattern it does bad things to my computer, as stated. Got to playing with appearances and chain link was the only one I could generate, but the background is black. I did figure out how to change the mesh size. Watched the YT videos where they pull up diamond plate, but I can't generate the image, just have to figure out what I'm doing wrong.
    Thanks for the help!
    i_r_
    Jun 2015
    Colorado
    387
    872
    145
    Yea, you'll want to use an appearance rather than actual features. If you get the appropriate texture map, you can get pretty realistic renderings.
    I run an overclocked I9 processor at 5.1GHz with 128GB of ram and can confidently state that features like what you're showing has a noticeable impact to performance in SolidWorks.
    Dec 2008
    Arizona
    1,680
    154
    198
    Fusion 360 blows away SW for this sort of thing
  11. Likes BugRobotics liked this post
