Extracting edges of STL model and projecting to plane...
Likes Likes:  0
Results 1 to 15 of 15
    Dec 2002
    Pacific NW
    5,118
    8
    834
    Default Extracting edges of STL model and projecting to plane...
    Any body know of software to do this, preferably free or open source?
    There is a youtube about converting stl's to solids using Fusion 360. That would do it after projecting the solid to a plane. Problem is the video is using the old Fusion format making it hard to follow since some features are renamed or different.
    May 2014
    Los Angeles
    431
    77
    Can you do it in onshape?
    Oct 2013
    New Jersey
    1,093
    907
    Not free but 40 sessions that can be 24 hrs will get it done. CamBam. About as simple but fairly capable CAM you will find.
    Jan 2019
    Tennessee
    467
    145
    121
    viacad does it. They give you a free 30 day trial with no limits. You can also "explode" features or edges off models and project them to your work plane.
    Dec 2014
    CANADA
    British Columbia
    1,280
    361
    585
    Solidworks can solidify STL files and then you could use either and intersection curve or “convert entities” on a suitable sketch plane.
    I’d be surprised if Spaceclaim couldn’t do it but I’m not more than marginally proficient.
    Dec 2002
    Pacific NW
    5,118
    8
    834
    Thanks for all the suggestions, my customer/friend found another solution.
    Dec 2008
    Arizona
    1,712
    157
    200
    Quote Originally Posted by Doug View Post
    And what was the solution. That way we can check it out.
    Dec 2002
    Pacific NW
    5,118
    8
    834
    Quote Originally Posted by len_1962 View Post
    Really simple solution. Import the stl file into FreeCAD, then export as a PDF. The PDF is scalable in Acrobat Reader which was a requirement. All free.
    I don't know about the accuracy, but this appears to be within the needs.
    Dec 2008
    Arizona
    1,712
    157
    200
    So all that was needed was a 2D document of the stl.?
    Dec 2002
    Pacific NW
    5,118
    8
    834
    Yes, that's what it turns out.
    Here's the whole story.... I use photogrammetry for work at times. Mostly related to work I do for artists and architectural restoration. This is not my usual type work, it does provide a nice break from more intense close tolerance work that's been my bread and butter. A non-CAD individual expressed interest in the photogrammetric process. For his needs he needed an outline or edge of the object in his .stl files exported from the photogrammetric software. That was the reason for my initial question, I wanted to give him a way to get the outline without monetary outlay.
    This exercise was an education for me. I didn't realize none of my usual three CAD programs couldn't do the simple projection from a mesh file. But then, I've never had the need to do it. I can machine directly from the .stl model.
  11. #11
    Sep 2009
    Apex, NC
    1,480
    729
    Unigraphics/NX will do it, it will project curves onto compound surfaces, offset curves on compound surfaces, split surfaces with those curves etc. The curves will need to be extracted or sectioned if starting with an STL file; sometimes that's the pain, since the STL files are not solids or surfaces. The STL files will create accurate cross-section outlines through any plane specified, so I've created numerous solid files by taking multiple sections of STL files. If it's not a time-consuming project, feel free to PM me and I'll give it a try (can export STEP, parasolid, dxf, iges etc).
    PDF's are vector files, so can be imported into Corel, etc, stripped of all the text and dimensions and such, export the iso views as DXF into NX and create solids from PDF drawing views.
  12. #12
    Dec 2008
    Arizona
    1,712
    157
    200
    Thanx for the answer and explanation.
    still leave me more questions or his stl, was it a scan or an stl from the web or one that was created by them?
    cause alot of different ways to skin the .....................
  13. #13
    Dec 2002
    Pacific NW
    5,118
    8
    834
    I don't know that an stl has actually been created yet by the person (I create them for my work). I told the individual about the photogrammetric software that would create and export an stl from a series of digital photos of an object. He then wanted to know how that stl could be converted into a scalable 2D outline (edge file) to print on paper. As I said I believe the person is not CAD proficient and probably wouldn't want to spend money on the solution or make it a research project.
    It never occurred to me initially that a PDF would be sufficient. In 35 years CNC'ing there's never been much need to play with stl's or PDF's. Lately due to learning what photogrammetry can do I've been working with mesh files, stl's and obj's, to do 3D printing and machining. There're several open-source softwares to manipulate stl's to prepare them for 3D printing in ways my various CAD software don't do easily. For 4th axis machining I use Bobcad because it's so fast and easy for me, but Bobcad can't do much in modifying stl's.
  14. #14
    Apr 2012
    UK
    30
    11
    Quote Originally Posted by Hazzert View Post
    Have looked at spaceclaim myself, video makes it look easy but not tried it yet
  15. #15
    Dec 2002
    Pacific NW
    5,118
    8
    834
    There's no shortage of programs that'll do the edge projection...... Problem is, a number of them cost big dollars. Autodesk had a few that were free, now when you go to the download link you find it's no longer free. I'll bet that's what will eventually happen with Fusion.
