Fanuc 5t Post Processor edits for Fusion 360 Help needed
Results 1 to 14 of 14
    Feb 2010
    North Carolina
    53
    Default Fanuc 5t Post Processor edits for Fusion 360 Help needed
    Is any one here using a Fanuc 5t or similar with Fusion 360? I am facing 2 problems (that I know of) One is the 5t does not recognize decimal points. The other problem is the G Code that is being out put drops any trailing zeros.
    I have edited my post processor Script with the following. But is only has the desired effect in part and is a poor and dangerous band aid in my opinion. X is pretty close to what it needs to be unless it ends in zero/s. The other z, etc sometimes get rounded up and also suffer the same problem with zeros being omitted.
    var xFormat = createFormat({decimals:0, scale:2000}); // diameter mode
    var yFormat = createFormat({decimals:0, scale:1000});
    var zFormat = createFormat({decimals:0, scale:1000});
    var rFormat = createFormat({decimals:0, scale:1000}); // radius
    var feedFormat = createFormat({decimals:0, scale:1000});
    Maybe there's some one here who is good with JavaScript? Or maybe another solution? If we can make it always post digits to the tenth I can manually edit out the decimals if need be. Any help would be very greatly appreciated!
    Mar 2015
    Michigan
    373
    74
    116
    Have you downloaded and read through the manual?
    Page 71 has some formatting information that could be helpful, and based on what you have posted currently I'm lead to believe that you have not referenced that material yet.
    Dec 2008
    Arizona
    1,712
    161
    201
    Have you gone to the HSM forum and asked in the post section for help?
    Feb 2010
    North Carolina
    53
    I posted in a few places looking for help with this to no avail. I am going to try and update those threads for anyone this may help. Hopefully this is correct it seems to work as intended in preliminary tests
    Ok so I have finally figured out how to assure that trailing Zeros are not dropped using a trim command, I have also added a forceDecimal command but for some reason it has no effect. I will say that I do not really know JavaScript so if you use the following edits please beware. I will just use the search and replace feature in note pad to delete the decimals. It would be nice if that were a user definable feature and I am sure it could be easily done. But I think I am happy for now. Hopefully this helps someone with a fanuc 5t or like machine.
    If anyone has any ideas for upgrades or edits I would be interested to hear.
    Please note I have had to add a space in the code at : ( because it shows in this thread as an emoji.
    var spatialFormat = createFormat({decimals: (unit == MM ? 3 : 4), trim:false, forceDecimal:false});
    var xFormat = createFormat({decimals: (unit == MM ? 3 : 4), trim:false, forceDecimal:false}); // diameter mode
    var yFormat = createFormat({decimals: (unit == MM ? 3 : 4), trim:false, forceDecimal:false});
    var zFormat = createFormat({decimals: (unit == MM ? 3 : 4), trim:false, forceDecimal:false});
    var rFormat = createFormat({decimals: (unit == MM ? 3 : 4), trim:false, forceDecimal:false});
    var feedFormat = createFormat({decimals: (unit == MM ? 3 : 4), trim:false, forceDecimal:false});
    Feb 2010
    North Carolina
    53
    Quote Originally Posted by dodgin View Post
    I actually was unaware of any such material until I found the following link this morning.
    https://cam.autodesk.com/posts/posts...ng%20Guide.pdf
    Thanks for taking the time to make the suggestion!
    Mar 2015
    Michigan
    373
    74
    116
    Quote Originally Posted by Tuff Luck Tom View Post
    Of course.
    I'm spitballing here, but it says that the default separator for a decimal point is '.'
    Have you tried to add in an empty separator character for your formats to see if that will force it to omit the decimal? It says that the forceDecimal specifier as false will only drop it for integer values. That's the next thing I would think to try.
    Feb 2010
    North Carolina
    53
    Quote Originally Posted by len_1962 View Post
    I have and had no response at all. I think I got it though. Thanks!
    Feb 2010
    North Carolina
    53
    Of course.
    I just searched the post using the search option in word pad for '.' and came up with no such characters in the post. But I found where it says just that in the training guide.
    Mar 2015
    Michigan
    373
    74
    116
    I don't think you'd find it in the post. If you don't designate your own separator it's going to go to a decimal point, which makes sense. I'd try to call out a separator in one of your format lines, but instead of using an actual character try to use nothing.
    Feb 2010
    North Carolina
    53
    Gotcha! Either my implementation of where is goes in the code is no good or it does not like having the field empty. That's ok. I can edit out the decimal with word/note pad I believe. This is obviously my first round with JavaScript lol...
  11. #11
    Mar 2015
    Michigan
    373
    74
    116
    If you go back to page 72 check out the last couple lines in the blue box. I'm looking at the var zFormat line. It looks like the function you need to force it into integer output is scale, then if you keep your forceDecimal at false it should drop the decimal output. I'm wondering what kind of other effect scale will have though...
  12. #12
    Feb 2010
    North Carolina
    53
    I edited the forceDecimal out. I think I like the idea of out puting g code with decimals and then using note/word pad to edit them out. This has been pretty easy so far. That way I can check over some of the moves more easily while there are decimals. I've been tied up with power outages and some things that are easy to run without cam so I haven't been able to give the whole shebang a real trial. Hopefully I've got this whole cam thing about in the bag. I'm ready for results lol. Thanks for the help!
  13. #13
    Mar 2015
    Michigan
    373
    74
    116
    Makes sense. Just for your information, not long ago I programmed super old Fanuc 4t and 5t machines...the format took a bit to get used to. Fortunately I was able to get my company to shell out about $500 for Cimco Editor that featured a backplot that graphically supported 4t and 5t format (among many others). Really helpful for me.
  14. #14
    Feb 2010
    North Carolina
    53
    That is helpful! I am pretty well still at the beginning of my journey with the 5t. The early version of some of the CAN cycles, using G50 and other formatting is a bit of a curve. I feel like I've spent the entire summer getting the machine going and getting up to speed. But it has been a good lesson and the cost of the machine was right. I would have been lost without the 5T manual. Thanks a ton for the info!
  15. Likes dodgin liked this post
