Fanuc ethernet port connection problem via Focas Library
Likes Likes:  0
Results 1 to 1 of 1
    Oct 2018
    TURKEY
    12
    10
    Default Fanuc ethernet port connection problem via Focas Library
    Hi everyone,
    I've got Fanuc Focas Library CD and I've coded a new app for monitoring controller in Python, called Focas library files (in windows and linux platform) those to access Fanuc controller via ethernet Focas1 (for controllers other then 30 series).
    I can connect to controller via IP and port numbers with telnet, ping and other cnc connection apps. But when I run my own code cnc_allclibhndl function of Focas library returns -16 (means no connection).
    Can you help?
