warner
- Aug 29, 2006
- New Hampshire
Currently working with Surfcam. I'd like to know if there is a way to create a spline (or complex curvature) by using the mathematical formula for that curve and the number of desired data points (or resolution of the curve). Of course, one can do the math and enter all the data points manually, but who has time for that? None of the cam systems allow direct interaction with the algorithm(s) they use for spline generation, probably because most do not generate curves in this fashion and/or they want to keep that part proprietary, but I'm in a position where having this feature would be vastly helpful in saving time. Anyone know of a fix (besides a new system)?
