Dear All,
I’m using Fusion 360 to generate G code to my 1994 build Robodrill which has Fanuc 16MA controller. Issue is that fusion does generate lot of lines in for example adaptive clearing. X and Y movements in every 0.1mm and if say I have specified feed to be 600mm/min it will never be able to reach that as the controller won’t be able to handle the code so fast. Or at least that is what I believe is the culprint.
So my question is, is there any way to streamline the code in Fusion 360 for older controllers? Or do I perhaps have too low RS232 baud rate selected that it is the bottleneck or?
Thank you in advance
