Hello,
I just joined PM and I was hoping to get a little help with Solid/Rigid tapping issue I'm having.
The Machine I'm using is a Kitamura MyCenter3x with a yasnac I80M controller I'm still just using HSM Express that I downloaded for free and is baked into my Solidworks.
My question is I have been trying to thread some aluminum parts using the solid tapping function and cannot get it to produce anything worthwhile. One weird thing is that HSM outputs a spindle speed at the beginning of the operation and then again in the G84 line of code. No matter what either one is set at before the tap goes into the part and while its initializing the spindle stops then begins to rotate very slowly while its descending into the part. I've deleted the Speed command in the G84 line and the same thing happens. I'm not quite sure what's going on or what if anything I'm doing wrong. Any help would be greatly appreciated. I'm attaching just a small example of the code I'm running for a tap cycle with a M10 x 1.5 hole. It looks like its working perfectly in the air but obviously something is off. I know that my spindle speed is too slow right now in the code below I'm just trying to keep it at something I can watch.
Thanks!
O00054 (M10 TAPPED HOLE)
(T0014 D=0.3937 CR=0. - ZMIN=-0.625 - RIGHT HAND TAP)
N10 G90 G94 G17
N15 G20
N20 G28 G91 Z0.
N25 G90
(DRILL3)
N30 M09
N35 T14
N37 M06
N40 S381 M03
N45 M08
N55 G00 G54 X1.875 Y-0.75
N60 G43 Z0.6 H14
N70 G00 Z0.2
N75 M03
N80 G93
N85 G98 G84 X1.875 Y-0.75 Z-0.625 R0.1655 F0.0591 S381
N90 G80
N95 G94
N100 Z0.6
N110 M09
N115 G28 G91 Z0.
N120 G28 X0. Y0.
N122 M05
N123 T20
N124 M06
N125 M30
Thanks!
N10 G90 G94 G17
N15 G20
N20 G28 G91 Z0.
N25 G90
(DRILL3)
N30 M09
N35 T14
N37 M06
N40 S381 M03
N45 M08
N60 G43 Z0.6 H14
N70 G00 Z0.2
N75 M03
N80 G93
N90 G80
N95 G94
N100 Z0.6
N110 M09
N115 G28 G91 Z0.
N120 G28 X0. Y0.
N122 M05
N123 T20
N124 M06
N125 M30
