Gibbs Cam CRC preferences
jgangnon
May 5, 2018
Has anyone had issues with Gibbs starting up in the incorrect CRC mode. I always use a cutter comp of 0.0000 regardless of tool diameter and then use the comp to adjust parts into size. In the Document box and in file preference (in two different places ) you can select
CRC "tool edge" or "tool center". I use "tool center". Sometimes that setting is inadvertently change to "tool edge". The part renders fine but the G code is posted expecting a D comp of the tool diameter to be input into the rad comp offset setting.
Is there a way to set the default to always be "tool center"?
Thanks Jeff
