GibbsCAM WFO POST HELP
Houdini
Titanium
Nov 28, 2017
I am trying to setup 2 parts in 1 program with 2 different (G54, G55) work coordinates.
I cannot get it to post correctly
I have part 2 shifted 5" over from part 1
Part 1 is in workgroup1, CS1, and has WFO 1 set, and all operation are programmed to use CS1
Paret 2 is in workgroup2, CS2, and WFO set to 2, and all operations programmed to use CS2
Haas POST processor, says it will accept NEWWFO settings.
Added NEWWFO(55) to the operation data pre
The post will output a G55 before the operations, but the posted codes positions are based on the other original CS
Any Ideas?
Just use the number of parts dialog in the post processor window. Set it to two and tell it to use new WCS. Each op has to be using G54 when posted it won’t increment G55 to G56.
