Help me to find the right CAD tool.
Results 1 to 4 of 4
    Dec 2018
    Washington
    Default Help me to find the right CAD tool.
    I have a small business where most of my design is electronic, and I have a CAD solution (Eagle) that is working well for me there. I also do a small number of mechanical designs - our cases are formed sheet metal, and I need to be able to generate and maintain those drawings. I then send the drawings out to a subcontractor who makes the cases for me. I only do about one case design per year. For the past 2 years, I have been using Fusion 360, which is working, but I am finding some things that are just not working for me: these include having the measurements relative to other objects in the design, rather than relative to an origin - and having everything in the cloud is just not working for me.
    Since I don't use Mechanical CAD daily, it is hard to justify a huge expense in order to purchase or rent it.
    I do use Corel Draw - primarily to do 2D designs which are sent to a laser cutter that we use in our process - but it doesn't seem to do 3D very well.
    I'm looking for a basic mechanical CAD package which will allow me to generate a set of drawings for my 'metal bender' which is relatively easy to learn, and not terribly expensive. Any suggestions?
    Mark
    Mar 2016
    CANADA
    Ontario
    107
    90
    61
    Draftsight for 2D CAD, AutoCad workalike but no $ cost.
    Fusion360 for 3D CAD with drawings as output. Also free. Lots of YouTube training available. Even does sheet metal: Fusion 36 Sheet Metal Tutorial! FF94 - YouTube
    Gerrit
  3. Likes mister honey liked this post
    Jan 2013
    Gilbert, AZ
    5,106
    6105
    6089
    Quote Originally Posted by gerritv View Post
    Gerrit
    You do realize you just recommended the CAD that he clearly said he is now using, and wants to get away from. Right?
  5. Likes doug925 liked this post
  6. #4
    May 2011
    No. Cal.
    318
    195
    I confess, I don't quite understand the 'can't dimension from an origin' complaint. OTOH, if internet access is a problem, or one is cloud-phobic then Fusion is a non-starter. You might take a look at the offerings from TurboCAD; less than $100.00 for their 2D/3D design offering.
    Fred
