How do I convert Fusion post processor to use in Solidworks.
Results 1 to 8 of 8
    May 2006
    Illinois
    230
    88
    38
    Default How do I convert Fusion post processor to use in Solidworks.
    I'm just starting to play with the Solidworks CAM package that comes with SW2018 and would like to use the post processor that I have been using for Fusion 360. Is there an easy way to convert them?
    gm
    Feb 2007
    Virtual, SF Bay Area, Tampa Area
    399
    184
    45
    Simple answer: no.
    Sent via GCode Editor @ 9600 baud
  3. Likes npolanosky liked this post
    Feb 2001
    Redwood City, CA USA
    4,940
    175
    882
    Quote Originally Posted by gmoushon View Post
    gm
    To what control are you trying to post? Is there no canned SW post that is at least close to what you need?
    May 2006
    Illinois
    230
    88
    38
    Quote Originally Posted by rklopp View Post
    My control is a Yasnac MX3. SW does have a Yasnac post processor that I can try. Its just that I ran into some minor kinks that I had to work out when using Fusion's Yasnac processor and was hoping there was an easy conversion. Should have known there wasn't.
    I'll see how it goes.
    gm
    Dec 2014
    CANADA
    British Columbia
    1,275
    361
    581
    Your two CAM systems are completely independent of each other. Whatever voodoo one speaks to spit out code for your machine the other most certainly doesn't.
    The only exception would be something like standalone MasterCAM and MasterCAM for Solidworks would use the same posts.
    Dec 2008
    Arizona
    1,697
    155
    198
    if you are using HSMWorks with SolidWorks, you do nothing, all Autodesk HSM use the same post.
    If it is SW CAM, MASTERCAM for SW, BOBCAM for SW you have to tweek or find one for your machine
    Oct 2012
    Orange county, CA
    89
    18
    SW CAM is simply a repackaged CAMWorks. If you can find a CAMWorks post for your machine, it should work
  9. #8
    May 2006
    Illinois
    230
    88
    38
    Update: I came across this link to a huge stash of CamWorks post processors that had the one I needed.
    It actually had the processor specifically written for my Kitamura with a Yasnac MX3 control! Thought I'd post the link in case anyone else needed a post processor.
    Dropbox - camworksposts.zip
    It is a HUGE zip file, (487MB), so I've attached the index that which lists all the machines are in the larger zip.
    Hope this helps.
    gm
    Attached Files Attached Files
  10. Likes mountie liked this post
