Mike RzMachine
Cast Iron
- Feb 4, 2007
- Utah
I've started using the G5.1 function on my robodrill and has a post processor question about it.
On hsmworks with the fanuc robodrill post, I switch the application of G5.1 on and off for an entire program in the postprocess tab under the data field "Use Smoothing". This applies g5.1 to all 2d/3d adaptive, contour, bore, etc. operations. If I don't want it to apply to some operation, is there a way to choose which specific operations to switch on G5.1 and leave it off for other operations?
Note, this is not the same as "smoothing" in the passes tab.
Mike
Mike
