HSMWORKS 2020 in Solidworks 2018: Can't Open Closed Contours.
Likes Likes:  0
Results 1 to 4 of 4
    May 2006
    Illinois
    239
    91
    38
    Default HSMWORKS 2020 in Solidworks 2018: Can't Open Closed Contours.
    Ok...maybe I'm missing something obvious, but I can't seem to change a closed contour into an open one so that I can select parts of that contour to machine.
    Seems relatively easy in Fusion 360: click on the closed contour and a mini menu pops up where you can change it to an open contour. Can't seem to do the same thing in HSMWORKS/Solidworks.
    Is this a bug, or am I missing something obvious?
    gm
    May 2007
    Mocksville, NC
    104
    You don't select contours the same way in HSMWORKS as F360. In HSM in the Geometry tap uncheck the Tangent Propagation and Propagate Along Z boxes, now you can select your individual lines to form the chains you want. IMO I like this a lot better than how F360 does it.
    May 2006
    Illinois
    239
    91
    38
    Thanks for the response. You're exactly right. Autodesk actually just contacted me and explained the same thing. (Something I didn't expect!) They also linked this video that explains it as well. YouTube
    gm
    Dec 2008
    Arizona
    1,712
    157
    200
    There is also another way without having to select a portion of a profile that the video doesn't show.
    see my screencast, use this method alot. select portion of profile in HSMWorks | Search | Autodesk Knowledge Network
    the second pick you have to hold down the shift key!
