HSMworks lead-in/lead-out
Likes Likes:  0
Results 1 to 3 of 3
    Oct 2014
    Maine
    1,065
    157
    502
    Default HSMworks lead-in/lead-out
    I am trying to machine the part shown in the picture. The actual machining is a straightforward step down with a face mill. Unfortunately, after the cutter clears the part, it is taking a wide loop, which will crash it into the vise. If I uncheck the lead-in and lead-out checkboxes on the linking tab, it gets rid of the green loops, but the cutting part is still looping out and away. Any suggestions on how to fix this?lead-.jpg
    Oct 2014
    Ohio
    218
    1141
    51
    Can you use a smaller tool? Looks like it's traveling outside the part to clear the cut.
    Can you change your cutting path geometry? These two videos may help:
    Roughing open slots
    Finishing open pockets and slots
    Jun 2009
    146
    89
    41
    Unselect the radii at the ends of the straight section in your geometry tab and turn on Tangential Extension (add/remove enough here to enter/exit where you want), and keep Lead In/Out on, just remove any horizontal and vertical radius. Use a short straight Lead In/Out if you need to keep comp on.
    Other than that, those radii at the ends of your geometry selection are what are driving the tool around like that.
