Import Kurt DX6 CAD file into Solidworks as an assembly file vs part file
Results 1 to 7 of 7
    Feb 2021
    Wisconsin
    14
    8
    Default Import Kurt DX6 CAD file into Solidworks as an assembly file vs part file
    Hey all.
    I'm new to using the Solidworks CAM portion of Solidworks. I am looking at importing a model of my DX6 vise to use in assembly layouts and simulations in CAM. I can only seem to find part files and not assembly files to download. I have tried downloading as a step file and saved the individual solid bodies. But I get an error when clicking "Create Assembly / browse button" in the window that opens to save the solid bodies.
    Kinda beating my head against the wall here. Can anyone offer any assistance?
    Thank you....
    May 2017
    Minnesota
    2,291
    3177
    1668
    I seem to recall you can save a multi-body SLDPRT file as a SLDASM file. There won't be any mates between the parts, but you can then add them.
  3. Likes AD Design, motofish84 liked this post
    May 2017
    Minnesota
    2,291
    3177
    1668
  5. Likes motofish84 liked this post
  6. #4
    Jun 2012
    Tennessee USA
    963
    638
    571
    Depending upon the version of SW you're using STEP files can come in as an import and without a feature tree even when saved as a Solidworks part file. Try adding reference geometry (axis, planes, points, etc.) at the component level that you'll need and save the file. This may allow you to create an assembly. Don't know what you'll be doing with this but I'd have the assembly as only 2 parts, the base/back jaw, and the moving jaw. Keeps it simple and a smaller file size. Hope this helped someone.
  7. Likes motofish84 liked this post
  8. #5
    Feb 2021
    Wisconsin
    14
    8
    Thanks to those who chimed in.
    It seems I was able to get it to work with a combination of things suggested.
    I downloaded it again as a part file then saved the solid bodies. Once saved as solid bodies I created an assembly from the part file. In the assembly screen I "floated" the moveable jaw and associated parts. Then I created new mates for these components as well as a distance mate for the movable jaw assembly.
  9. Likes AD Design, Qwan liked this post
  10. #6
    Sep 2013
    Minnesota
    360
    137
    88
    Quote Originally Posted by motofish84 View Post
    If you mate the jaws to the part, then modify the part, your vise assembly will change with it automatically. This can be especially valuable if you are collision checking against vises, fixtures, vise stops, or whatever. In essence this is how the reuse library works in NX and can be used standalone or with a machine simulation.
    Let the software do the work for you.
  11. #7
    Jul 2020
    Washington
    85
    31
    27
    You can Import(open) STP files as an assembly into your assembly template file.
    Go to System Options -> Import -> File Format and change it to STEP/IGES/ACIS
    Then under the Options section on the same dialogue, set Import Multiple Bodies as Parts. This will pull it in as and assembly using your assembly file template. If you have the Import assembly as multi-body part, then it will pull it in a part file template which I believe is the default setting. I also check the Auto Import Diagnostics to help heal gaps and whatnot that seem to be common with STEP files and SW.
    Now just file open(or drag and drop into SW empty screen) your part and the new assembly file will be populated with all the parts as individual components.
    Now, you can choose to save each part individually as a part file external to the main assembly file. This is nice for a typical SW assembly workflow. I usually save the parts internal, that way there is only a single file for the whole assembly. You still get the same functionality.
    Also, be sure to Break the External links on your imported step file. It can keep you from making modifications to the new assembly.
  12. Likes motofish84 liked this post
