Importing 3D Model into MasterCam and Nesting Multiple Part Files
Results 1 to 14 of 14
    Aug 2018
    Oregon
    7
    Post Importing 3D Model into MasterCam and Nesting Multiple Part Files
    Hey everyone,
    Is it even possible to import 3D models into an existing MasterCam file? Here's the scenario.
    1. You spent valuable time writing a program to cut Part1 on your CNC router.
    2. Now you have another part, Part2, that you need to write a CAM file for and you want to nest this part with Part1 in the final program.
    3. Within nesting, you go to parts -> "add operation clusters from files" (see attached image). You choose Part1 file and nothing imports. For some reason this doesn't work at all. Thanks MasterCam.
    4. You try another route. You open the Part1 mcam file and "export all operations and geometry."
    5. You go back to you Part2 mcam file. You right click on the left pane (other attached image) and click "import toolpath operations." You choose the Part1 .mcam-operations file that you just exported in step 4 and MasterCam says it can't import 3d geometry. The operations all get imported, but they no longer have chains associated with them becuase MasterCam didn't import the 3d model!
    Is there something I am missing?
    Thanks for your time,
    Seth
    Attached Thumbnails Attached Thumbnails nestingoptions.jpg   importrightclick.jpg
    Dec 2008
    New York
    10,051
    2615
    i have imported 3D model then
    create curves and select edges. be careful as radiused or rounded edges make it difficult to select edges.
    worse is .010 rounded corners or edges and you dont see because small and you end up .010" off from expected
    even holes you end up creating curves at edges of holes that way you can select the holes by selecting the curves basically wirefreame you put in or on the 3D file
    Nov 2007
    canada
    703
    93
    375
    Yes, Mastercam can import solids into an existing file...would be useless if you couldn't.
    Yes, you can nest parts within other parts, within the main sheet.
    If you want to import a saved operations geometry then check the box to do so. Sometime reading the menu in front of you can be very helpful.
    Jun 2012
    Michigan
    4,628
    4239
    2795
    Yes, File-Merge
    Dec 2008
    New York
    10,051
    2615
    emastercam has many tutorial books on learning mastercam
    Aug 2018
    Oregon
    7
    Quote Originally Posted by goooose View Post
    I have read the menu goooose. Checking the "import saved operations geo" box does not import 3d model geometry. Does yours?
    Aug 2018
    Oregon
    7
    Quote Originally Posted by Mtndew View Post
    Yes, File-Merge
    This works. Thank you for such a simple answer Mtndew. I wish it imported the operations with it though.
  8. Likes Mtndew liked this post
  9. #8
    Mar 2003
    285
    17
    24
    In the Toolpath window select the operations you want to save then right click and "Export". You will get a file save style menu so you can choose where to save the operations. In the new file right click again and "Import" from the saved operations file. I use it for family parts all the time. As far as I know you will still have to use "Save Some" and "Merge" for the geometry.
  10. Likes mpuvdd liked this post
  11. #9
    Aug 2018
    Oregon
    7
    Quote Originally Posted by William Ward View Post
    And then rechain to the merged geometry? Thanks William!
  12. #10
    Aug 2018
    Oregon
    7
    UPDATE: It seems that Mastercam corrupted the original file. Since then, I have gone through and saved a separate Mcam file for each part respectively. I now have a parent Mcam file that has one nesting operation pulling "operation clusters" from each child file.
    To my surprise, the nesting operation actually imported the original 3d parts from the child files.
    Now I can just run one program and choose the quantities of each part to nest into a sheet on my router. Hope this helps someone in the future.
  13. Likes avongil liked this post
  14. #11
    Mar 2003
    285
    17
    24
    I remembered last night that there is an option to save the geometry with the operations when exporting. I don't use it that way so I'm not sure exactly what you get, just adding the info in case it's of use.
    I'm happy to hear that you have a process worked out. Getting those sorts of things set up will save you tons of time and head scratching in the future.
  15. Likes mpuvdd liked this post
  16. #12
    Aug 2018
    Oregon
    7
    Thanks William. It turns out that exporting geometry with operations does not actually export 3d geometry, only wireframe. This would be a good revision to add to Mastercam.
  17. #13
    Dec 2014
    163
    17
    28
    It only exports the geometry associated with the toolpath. So if you had a toolpath driven by even just one edge of the solid it will export/import the solid also.
    You could add a dummy operation that does nothing but uses the solid to drive it. That would also export the solid if you exported all ops.
    AG
  18. #14
    Jun 2013
    1,036
    713
    452
    Cntl drag/drop
    Shift drag/drop
    ... Couple more ways to get models into mastercam.
    Once you have a method perfected you can either save it to defaults and or save it as an operation file for later import. Or just save the MC file somewhere and us it for a template, to import geometry into.
    It's pretty cool on rare occasions to crunch a program for 30min the runs for 12 hrs.
  19. Likes Mtndew liked this post
