Having a bit of trouble understanding your question, so hope this helps...
If you are in a drawing, then choose Dimension, then right mouse click to get intersection option and pick two edges to form the intersection point for first dimension point. Choose second reference edge or repeat the intersection process for second point to complete the dimension .
If you have a model, need to establish a point(s) to dimension from. Start sketch on surface and project edges that will form intersection. Pick Point tool, right click and choose Point Snap - Apparent Intersection; now click on projected edges and Point will be placed. Now dimension from edge to that point (or between points you have created).
Fred
