Inventor CAM & G112 - Engraving
Likes Likes:  0
Results 1 to 1 of 1
    Jan 2020
    NORWAY
    52
    31
    5
    Default Inventor CAM & G112 - Engraving
    Hi,
    Has anyone here found an efficient way to do engraving wrapped around a bolt for instance?
    It's super easy for planar engraving - just select the text and away you go.
    However, for engraving on something that's not flat then it's a royal pain in the ##.
    Seems like I need to pick one line segment at a time in the geometry selection tab. Engraving function does not work very well for this, so i think 2D pocket or contour is the way to go.
    Would be great if Haas made a VPS template for this where you just pick the location, stock OD, orientation and the text you want to inscribe. Super happy with our new ST-30Y and its pre-made templates are fantastic.
    Cheers,
    John
