Machining a slot on SolidWorks
Results 1 to 7 of 7
    Jan 2020
    Florida
    Default Machining a slot on SolidWorks
    Image 1
    Image 2
    Image 3
    Image 4
    Hello everyone,
    I am a beginner at SolidWorks CAM and I am encountering some trouble machining the slot inside of that button part. As you can see in image 1, I already have most of the part figured out except for that blue area. I have tried defining the feature as a pocket and when I attempt to do a contour operation it only trims off the top and goes around. When I try defining the feature as a slot, it doesn't create a path for a contour operation. I am using a 2.5 axis mill to make this part. Dimensions can be seen in images 2 and 3. It's a 0.25" x 0.63" x 0.81" slot. I should also add that I am using a keycutter with the dimensions specified in image 4.
    Feb 2013
    Madison, WI
    1,042
    1143
    677
    I would do it as an open profile. Select the two bottom edges and the bottom inside radius(so 3 segments). Do not select the od segment.
    If you wanted to do a cam supported roughing op, make it as a corner slot with the od edge as an open air segment. This should give you a rough and a contour toolpath.
    Dec 2008
    Arizona
    1,719
    165
    205
    draw a sketch at the centerline and drive the cutter with the sketch, do not use cutter comp. I am assuming the cutter is the same dia. as the cut.
    Just looked at the cutter info it's dia is .78 and you are cutting a .32 radius= .64 dia wont fit!!!
    the only problem is what will SW CAM do at the end of the cut? will it try and lift out thru the part.
    some time for thing like this it is just better to hand GCode the operation so you know what it will do, CAM not always the answer. Sorry.
    Aug 2005
    CT
    7,825
    326
    1862
    Quote Originally Posted by len_1962 View Post
    Yeah.. S'plain THAT to some of the current CAMMasters of the Universe!
    With that said, in FeatureCAM that would be a sub 2 minute shenanigan.
    Mar 2016
    Illinois
    358
    76
    189
    Use an open profile feature and follow the outside diameter with a smaller cutter.
    Apr 2007
    West Virginia
    1,065
    549
    421
    Quote Originally Posted by SeymourDumore View Post
    Assuming you know how to use it, which seems to be the problem in this case not so much the tool.
    And I don't think G code will make that cutter fit in that slot.
    Aug 2005
    CT
    7,825
    326
    1862
    Quote Originally Posted by Pete Deal View Post
    Hence my cammaster comment.
    Not sure which picture to believe, but it does not look like either the shank, nor the business end would fit.
  8. Likes len_1962 liked this post
