Usually the extrude feature works ok, sometimes you have to fight the toggles as it defaults to " create body" and "thin wall" (under advanced), but after that it will typically cut a solid fairly well. On this one I'm getting this weird Boolean error. It cut the left wide of the circle fine, right side i get this . Changing the cut distance does not remove error
any help appreciated
