MasterCam Copying Holes
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Sep 2003
    Alabama
    25
    Default MasterCam Copying Holes
    I want to copy a hole 100 times. I need each hole to be .0156 farther than the last. Example: .500, .5156, .5312, .5468, .5624, .5780, etc.. Is there a way to do this other than one hole at a time?
    Nov 2007
    canada
    796
    108
    472
    VBScript or Chook will work.
    Sep 2018
    17
    11
    6
    Yes erase all holes except the first starting hole. Highlight first hole then go to transform tab at the top (Mastercam 2020) and click translate on method click copy. Number of Instances 100 then delta x or y .0156
    Sep 2006
    Long Island, New York
    743
    350
    125
    Do you mean you need them to be .0156 apart from each other? Tranform, Translate, Number of instances.
    Sep 2006
    743
    350
    125
    If you mean you need to add an additional .0156 each time, then I don't know of any way out of the box to do it.
    It was interesting so I tried. Best thing I came up is to copy the line a bunch of times and count the spaces adding one each time. I did point but obv you could do circles. Tedious but I did 10 of them pretty quick.
    I thought there was a C-HOOK included that did a variable pitch spiral, but I could only find one that does a fixed pitch. Then you coukd have drawn a line across it and put circles at the intersections.
    Sep 2003
    Alabama
    25
    Quote Originally Posted by Volitan View Post
    Yes, this is what I want to do. I may have to do it like you said. You would think a powerful as Mastercam is it could do this.
    Nov 2007
    canada
    796
    108
    472
    Wait, after reading your post again, if you just want a hole every 0.0156 Translate works fine. Just translate 0.0156 in whatever direction and set the number of instances to 100. I thought you were wanting the gap to increase as well with each move, which would need a script or chook to do. What you're after is just normal translate.
    Sep 2003
    Alabama
    25
    Ok, lets try this......if I have a set of gage pins that start at .500 and goes up to 3.000 in 1/64 increments. I want to program the center points of all these pins so that when they are pressed in a plate a .500 gage block will just fit between all of the pins.
    Jun 2012
    Michigan
    5,913
    5579
    3771
    Quote Originally Posted by XxLT250RxX View Post
    It can't work miracles, what you're wanting to do is way out of the normal.
    If you ask on the official forums there is a chance that someone there can write you a script or Chook that can do what you want. Some very smart people over there.
    Feb 2020
    Alabama
    366
    151
    104
    NX can do it easily.
  11. #11
    Feb 2020
    Alabama
    366
    151
    104
    Mastercam if FAR from being a powerful design tool. It never will be a powerful design tool. A design tool should be capable of using parametric formulas. MC doesn't even come close. Hell. you can barely get that shit to do dimensioning without pulling your hair out.
  12. #12
    Jan 2014
    Temecula, Ca
    3,340
    1405
    4353
    I did this in mastercam years ago, in V9 I beleive. I haven't used mc in years so I don't remember how, but it is possible.
  13. #13
    Sep 2006
    743
    350
    125
    Quote Originally Posted by Larry Dickman View Post
    I'm thinking maybe a formula in the FPLOT c-hook it ships with but I won't have a chance to play with it until lunch.
  14. #14
    Nov 2007
    canada
    796
    108
    472
    Ok, I think I'm back on track now. So my original response is what you need, a script or a chook/nethook. This way you can define the varying parameter. Also, keep in mind you can do this with macros as well.
    Do you know how to run scripts in Mastercam?
  15. #15
    Nov 2014
    Florida
    6,257
    2487
    3099
    Quote Originally Posted by CORONA VIRUS View Post
    more words here
  16. Likes Mtndew liked this post
  17. #16
    Nov 2007
    canada
    796
    108
    472
    Oh, one more option I just thought of. You can create a CSV file with the coordinates and import that into Mastercam. So in excel you would put X of the first point in A1, y in A2, z in A3, point 2 would be in row 2 etc. So now you can use fomulas in excel to generate the spacing automatically for your 100 points. Open the CSV file in Mastercam and this will plot the points. If you want circles at these points use the PointsToCircle chook.
  18. Likes Volitan liked this post
  19. #17
    Sep 2006
    743
    350
    125
    Quote Originally Posted by goooose View Post
    nice
    10 characters
  20. #18
    Feb 2016
    CANADA
    Ontario
    10
    Interesting topic. I think I might do a video up on this.
    Hope no one minds me using this forum as an idea generator for some videos
  21. #19
    Feb 2020
    Alabama
    366
    151
    104
    more words here
    You do understand that Mastercam claims to have a design package, right? In fact, you have to pay money for it.
  22. #20
    Mar 2015
    Michigan
    540
    130
    243
    Do everyone on this board a favor and, pretty please, turn your fucking brain on before you post any more.
  23. Likes Mtndew, Mike1974, SeymourDumore liked this post
