Mastercam maintenance increase - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 71
  1. #41
    Jun 2012
    Michigan
    4,730
    4336
    2876
    Quote Originally Posted by 316head View Post
    2020 is definitely not that great and the core problems still persist.
    What core problems are you referring to?
  2. #42
    Apr 2006
    Ga.
    130
    11
    12
    I run 2020 all day and it runs pretty damn good for me.
  3. Likes Mtndew liked this post
  4. #43
    Jun 2012
    Michigan
    4,730
    4336
    2876
    Quote Originally Posted by rickyt View Post
    Same here, only 1 crash in the last couple of months that I've been using it daily.
    It seems more stable than 2019 in that regard. I've dubbed 2019 Crashtercam.
  5. Likes dodgin liked this post
  6. #44
    Jan 2019
    66
    41
    40
    Upgraded for 3 years and got a 15% discount....comes out to about $100/month.
  7. #45
    Feb 2018
    DENMARK
    198
    12
    135
    I am a old mastercam guy. Used mastercam for alot of years up to x6.
    Been using inventor hsm for a few years and I like it.
    But comparing these twos you cant.
    Inventor hsm does the job for me but I still loved the workflow in mcx.
    I don't do much cad
    Sendt fra min EML-L29 med Tapatalk
  8. #46
    Jul 2006
    EU
    12
    Our maintenance cost increased 60%
    We have Mill, Mill 3d, lathe and lathe entry licenses.
    We are looking other options now
  9. #47
    Jun 2006
    Alabama
    1,883
    1089
    738
    Quote Originally Posted by Mtndew View Post
    MC 2020 killed a part for me yesterday. Not in Backplot or Verify. Sent the tool straight through a wall.
    The only way I can run a Dynamic path now is to check Full Vertical Retract.
  10. #48
    Jun 2012
    Michigan
    4,730
    4336
    2876
    Quote Originally Posted by Rstewart View Post
    I was referring to software crashes.
    Machine crashes if/when they happen are my fault, unless an operator fucked up by editing the program.
  11. #49
    Nov 2007
    canada
    710
    93
    383
    Those dogleg rapids will get you every time. Not the softwares fault, either setup Mastercam correctly to simulate doglegs or setup your machine to not rapid with doglegs.
  12. Likes rickyt liked this post
  13. #50
    Sep 2018
    Arizona
    17
    6
    Quote Originally Posted by goooose View Post
    Basically this. FeatureCam will do this too.
  14. #51
    Jun 2006
    Alabama
    1,883
    1089
    738
    Sorry just now getting back to this.
    There was no dogleg... I only use the higher feed method getting around a part when dynamic-ing a part. Basically the path avoids uncut material by a set amount with a G01 feed you specify. Zero G00's except for the entry and exit move.
    I've been using dynamic since they have implemented it years ago. Never had this happen before.
    If you select Full vert retract to avoid a boundary it's safe, just a Lot of retracts.
  15. #52
    Feb 2007
    Aberdeen, UK
    3,613
    1250
    1377
    How do transfer your programs onto the control?
    I had an unexpected gouge a few weeks ago, tool went clean through a wall when it should have gone up and over. Fucked up a part that we had nearly a week of work on already.
    After close examination I found those lines were neatly missing from the program on the control, but were present in the posted code on the pc.
    We transfer all programs to that machine by usb pen drive. I found the lines were also missing on the pen drive. We are always careful to unmount the drives properly before we pull them and only use decent brand name pen drives, so the only possible explanation is either windows being a flaky piece of shit or the pen drive being a flaky piece of shit. Either are equally likely IMO.
    I did not think it was possible in this day and age to have undetected data corruption on a (semi - ntfs) modern filesystem and modern hardware. Just goes to show that windows does not do much in the way of error checking when writing to removable media.
    I sat down right then and there and ordered everything I needed to run ethernet to all the usb machines. (Haven't got around to actually doing it yet tho...)
    And smashed that pen drive up with a big f*ing hammer just to be sure...
  16. #53
    Oct 2007
    SPAIN
    3,547
    1995
    1292
    Quote Originally Posted by gregormarwick View Post
    HolyMoly!!!
    You talking Fanuc here Gregor?
    Have you spoken with them?
    When I had my place (they're still going so still doing it) for all the big trocoidal toolpaths, we spat them out from Mastercam as an external sub, and put that on the PCMCIA card.
    So the main prog would fit in the (eenyweeny) control, and the roughing paths would be taken from the card.
    It worked like a charm.
    BUT what you've described here could easily wreck a machine...
  17. #54
    Feb 2007
    Aberdeen, UK
    3,613
    1250
    1377
    Quote Originally Posted by barbter View Post
    HolyMoly!!!
    No this was on one of our Hurcos, although we do use the pcmcia cards on the Fanucs as well.
    No fault of the machine, it accurately read what was on the pen drive.
    The program was posted 100% correctly, somehow lost a few lines when copied to the usb drive. Windows made no indication that the file was not copied properly.
    As soon as I can find the time to make it happen, we will completely ethernet apart from the odd couple of machines that are still serial, and zero removable media.
    Windows is cheap shit garbage and all pc hardware is cheap shit garbage, and none of it should be trusted for anything important, IMHO.
  18. #55
    Feb 2014
    Sunny South West Florida, USA
    2,881
    10698
    3274
    I've no idea what a license costs, but the software BeyondCompare lets you choose two files (in your case, the program on the USB and the program on the PC) and do a quick compare. It will put the two side by side, and highlight any differences between them. Or, if they compare exactly the same, it can simply give you a popup that they're identical. I use it to check revisions and such, and it's a really great piece of software. I realize it's an extra step, and if you switch to ethernet only, it's unnecessary, but I figured I'd mention it so you would be aware it existed.
    Edit: I just went and looked, because I was curious. It's incredibly cheap, and you can even download a demo to try it out: Buy Beyond Compare
  19. Likes Mtndew, barbter, gregormarwick liked this post
  20. #56
    Jun 2012
    Michigan
    4,730
    4336
    2876
    Quote Originally Posted by TeachMePlease View Post
    Just to add, if people have Mastercam they can do the same thing with Cimco.
  21. Likes TeachMePlease liked this post
  22. #57
    Feb 2007
    Aberdeen, UK
    3,613
    1250
    1377
    Thanks for the tip - I have several tools in my arsenal to do a diff compare, but like you said it's an extra step that should not be, and never has been before, necessary.
    This is the kind of thing that you read about being pushed out unnoticed in a windows update and causing havoc. Don't think that was the case here though. None the wiser as to the cause.
  23. #58
    Sep 2018
    389
    520
    162
    It gives you the security of "free" upgrades to the newest version.
    Let's say that next year's software comes out with a toolpath that reduces your cycle times immensely..you'd be losing money.
    But if you want that new version then you'd have to pay full price for all 5 seats, and that's a lot of dough.
    Regardless, I know a lot of people on both sides, some on maintenance, and some not. All are happy.
    except masterBLOW has done nothing significant in several years. they got complacent in the market, and soon will start to lose market share.
  24. #59
    Jun 2012
    Michigan
    4,730
    4336
    2876
    Quote Originally Posted by empwoer View Post
    People like you make me laugh.
    Those who think Mastercam sucks have never taken the time to set it up correctly.
  25. #60
    Oct 2007
    SPAIN
    3,547
    1995
    1292
    Gregor, +1 for Beyond Compare.
    Scooter Software Rocks!
    It was 30 bucks by memory when I bought it - one of the best purchases I made!
  26. Likes TeachMePlease liked this post
