10720 error Siemens 840D, code wont run, how to check zero offsets?
markp
Hot Rolled
Oct 7, 2006
Petaluma CA 94952
Im trying to test a post processor for my DMG DMU103V with 840D control. I can run a few lines then any axis movement causes a 10720 error. This a software limit error somehow related to the zero offsets. The part WCS is in the middle of the table so theres no way its close to any hardware or software limit. Any suggestions on how to clear this type of error? Is it somehow related to some global Machine coordinate?
Heres a pic of my workpiece limits. Seems kind of large. I didnt set these except maybe by accident. Seems like plenty of room.
Same error when trying to run in MDI. Heres the program. This post is supposed to be for a DMG DMC63V with 840D. Also error is in every axis ie: if I remove Z moves, error is in next axis, either Y or X, whatever is first.
; O1112
;DECKEL MAHO 840D
T1
M6
;TOOL 1
;OPERATION 1
G54
S4278 M3
G90 G00
Z0.8 M9
G00 X0.75 Y0.75 Z0.4
F4.3
R2=0.4 R3=0.17 R10=0.4
G81
X0.75 Y0.75
G80
G00 Z0.8
G00 M9
G00 Z1. M5
M1
T2
M6
;TOOL 2
;OPERATION 2
G54
S2674 M3
G90 G00
Z0.4 M9
G00 X0.75 Y0.75
G83 G98 X0.75 Y0.75 Z-1. Q630 R0.4 F10.1
G80
G00 Z0.8
G00 M9
G00 Z1. M5
M1
T4
M6
;TOOL 4
;OPERATION 3
G54
S3500 M3
G90 G00
Z0.8 M9
G00 X0.7367 Y-0.2874 Z0.4
G01 Z-0.1 F28.0
X0.738 Y-0.1874
G02 X-0.1875 Y0.75 I0.012 J0.9374
X0.75 Y1.6875 I0.9375 J0
X0.9072 Y1.6742 I0 J-0.9375
G01 X0.924 Y1.7728
G00 Z0.4
X0.7367 Y-0.2874
Z0.3
G01 Z-0.2
X0.738 Y-0.1874
G01 X0.924 Y1.7728
G00 Z0.4
X0.7367 Y-0.2874
Z0.2
G01 Z-0.3
X0.738 Y-0.1874
G01 X0.924 Y1.7728
G00 Z0.4
X0.7367 Y-0.2874
Z0.1
G01 Z-0.4
X0.738 Y-0.1874
G01 X0.924 Y1.7728
G00 Z0.4
X0.7367 Y-0.2874
Z0
G01 Z-0.5
X0.738 Y-0.1874
G01 X0.924 Y1.7728
G00 Z0.4
Z0.8
M9
G80
G00 Z1. M5
G90 X0 X0
M30
Rube siemens mistake, I used base zero to set my WCS at some point in my first attempt at setting up tools and work offsets. I didnt realize that base zero is siemens speak for machine coordinate system. I see that every 840d seems to have a different way to reset this usually involving setting parameters, but on the DMG its just a matter to selecting "base" in the scratch window and setting all the axis to zero. I had the z axis off by about 18" so it gave Z errors when trying to run a program. I reset and now I can run programs fine.
