Mitsu Meldas Post change Z retract between workOffset
Hardplates
Stainless
May 8, 2019
What once was a free country
In the past I have just modeled all the parts in the same work offset but I rather not do that anymore. Currently my post (fusion, inventor, hsm) retracts Z to home when changing work offsets. Ideally I would like is to retract say 3" from safe Z but I could get by with just going to safe Z as most of the time my Z heights between fixtures are very close. I guess I would like to modify a couple posts to retract different amounts for different work.
I'm not very good at coding and can't seem to find it in the post. Does anyone know what I should be looking for?
I can post my post but it will likely take a couple posts. :nutter:
Paul
Maybe I’m misunderstanding, but in Fusion Cam you can change the retract height offset.
That is for that particular operation. If you create two setups with different work offsets it is up to the post to determine what to do when going from say G58 to G59. The generic Meldas post which mine is based off of goes
G28 G91 Z0;
G90;
If I could get it to go
G91 Z2.0;
G90;
that would be great
(FACE3 6)
M09
M01
T39
M06
T3
S700 M03
G59
M08
G00 X-1.95 Y3.4625
G43 Z1.594 H39
Z1.272
G18 G02 X-1.65 Z0.972 I0.3 F14.
G01 X-1.6
X6.1
G02 X6.4 Z1.272 K0.3
G00 X-1.95 Y1.448
G01 X-1.6
X6.1
G00 Z1.594
G17
G28 G91 Z0.
G90
(FACE3 5)
G58
G00 X-1.95 Y-0.5375
G43 Z1.594 H39
Z1.272
G01 X-1.6
X6.1
G00 X-1.95 Y-2.552
G01 X-1.6
X6.1
G00 Z1.594
G17
M09
G28 G91 Z0.
G90
G28 G91 Y0.
G90
M30
