Hardplates
Stainless
- May 8, 2019
- What once was a free country
At the end of the program it sends X and Y home via
G28 G91 X0. Y0.;
This is a pain because then the work is usually not in front of the door. I would like it to just send Y home and omit X
My post is as follows. I'm not sure quite sure what to change and figured I'd ask before I go playing around with it. Thanks in advance
preloadTool: true, // preloads next tool on tool change if any
showSequenceNumbers: true, // show sequence numbers
sequenceNumberStart: 10, // first sequence number
sequenceNumberIncrement: 5, // increment for sequence numbers
optionalStop: true, // optional stop
o8: false, // specifies 8-digit program number
separateWordsWithSpace: true, // specifies that the words should be separated with a white space
useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words.
useRigidTapping: "yes" // output rigid tapping block
// user-defined property definitions
propertyDefinitions = {
writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
writeTools: {title:"Write tool list", description:"Output a tool list in the header of the code.", group:0, type:"boolean"},
preloadTool: {title:"Preload tool", description:"Preloads the next tool at a tool change (if any).", type:"boolean"},
showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
optionalStop: {title:"Optional stop", description:"Outputs optional stop code during when necessary in the code.", type:"boolean"},
o8: {title:"8 Digit program number", description:"Specifies that an 8 digit program number is needed.", type:"boolean"},
separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
useRadius: {title:"Radius arcs", description:"If yes is selected, arcs are outputted using radius values rather than IJK.", type:"boolean"},
useRigidTapping: {
title: "Use rigid tapping",
description: "Select 'Yes' to enable, 'No' to disable, or 'Without spindle direction' to enable rigid tapping without outputting the spindle direction block.",
type: "enum",
values:[
{title:"Yes", id:"yes"},
{title:"No", id:"no"},
{title:"Without spindle direction", id:"without"}
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-";
var singleLineCoolant = false; // specifies to output multiple coolant codes in one line rather than in separate lines
// samples:
// {id: COOLANT_THROUGH_TOOL, on: 88, off: 89}
// {id: COOLANT_THROUGH_TOOL, on: [8, 88], off: [9, 89]}
var coolants = [
{id: COOLANT_FLOOD, on: 8},
{id: COOLANT_MIST},
{id: COOLANT_THROUGH_TOOL, on: 88},
{id: COOLANT_AIR},
{id: COOLANT_AIR_THROUGH_TOOL},
{id: COOLANT_SUCTION},
{id: COOLANT_FLOOD_MIST},
{id: COOLANT_FLOOD_THROUGH_TOOL},
{id: COOLANT_OFF, off: 9}
var gFormat = createFormat({prefix:"G", width:2, zeropad:true, decimals:1});
var mFormat = createFormat({prefix:"M", width:2, zeropad:true, decimals:0});
var hFormat = createFormat({prefix:"H", width:2, zeropad:true, decimals:0});
var dFormat = createFormat({prefix:"D", width:2, zeropad:true, decimals:0});
var xyzFormat = createFormat({decimalsunit == MM ? 3 : 4), forceDecimal:true});
var rFormat = xyzFormat; // radius
var abcFormat = createFormat({decimals:3, forceDecimal:true, scaleEG});
var feedFormat = createFormat({decimalsunit == MM ? 0 : 1), forceDecimal:true});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-99999.999
var milliFormat = createFormat({decimals:0}); // milliseconds // range 1-9999
var taperFormat = createFormat({decimals:1, scaleEG});
var rigidTapFormat = createFormat({prefix:",R", decimals:0});
var pitchFormat = createFormat({decimalsunit == MM ? 3 : 4), forceDecimal:true});
var peckFormat = createFormat({decimalsunit == MM ? 3 : 4), forceDecimal:true});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({onchange:function () {retracted = false;}, prefix:"Z"}, xyzFormat);
var aOutput = createVariable({prefix:"A"}, abcFormat);
var bOutput = createVariable({prefix:"B"}, abcFormat);
var cOutput = createVariable({prefix:"C"}, abcFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
var dOutput = createVariable({}, dFormat);
var pitchOutput = createVariable({prefix:"F", force:true}, pitchFormat);
var peckOutput = createVariable({prefix:"Q", force:true}, peckFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I"}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J"}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K"}, xyzFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G93-94
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21
var gCycleModal = createModal({}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99
var WARNING_WORK_OFFSET = 0;
// collected state
var sequenceNumber;
var currentWorkOffset;
var retracted = false; // specifies that the tool has been retracted to the safe plane
function getWCSDescription(workOffset) {
if (workOffset == 0) {
workOffset = 1;
if (workOffset > 0) {
if (workOffset > 6) {
var p = workOffset - 6; // 1->...
if (p <= 300) {
return gFormat.format(54.1) + " P" + p; // G54.1P
} else {
return gFormat.format(53 + workOffset); // G54->G59
return "#" + workOffset + "(" + localize("not supported") + ")";
Writes the specified block.
function writeBlock() {
if (!formatWords(arguments)) {
return;
if (properties.showSequenceNumbers) {
writeWords2("N" + sequenceNumber, arguments);
sequenceNumber += properties.sequenceNumberIncrement;
} else {
writeWords(arguments);
Output a comment.
function writeComment(text) {
writeln("(" + filterText(String(text).toUpperCase(), permittedCommentChars) + ")");
function onOpen() {
if (properties.useRadius) {
maximumCircularSweep = toRad(90); // avoid potential center calculation errors for CNC
if (!machineConfiguration.isMachineCoordinate(0)) {
aOutput.disable();
if (!machineConfiguration.isMachineCoordinate(1)) {
bOutput.disable();
if (!machineConfiguration.isMachineCoordinate(2)) {
cOutput.disable();
if (!properties.separateWordsWithSpace) {
setWordSeparator("");
sequenceNumber = properties.sequenceNumberStart;
writeln("%");
if (programName) {
var programId;
try {
programId = getAsInt(programName);
} catch (e) {
error(localize("Program name must be a number."));
if (properties.o8) {
if (!((programId >= 1) && (programId <= 99999999))) {
error(localize("Program number is out of range."));
} else {
if (!((programId >= 1) && (programId <= 9999))) {
if ((programId >= 8000) && (programId <= 9999)) {
warning(localize("Program number is reserved by tool builder."));
var oFormat = createFormat({widthproperties.o8 ? 8 : 4), zeropad:true, decimals:0});
if (programComment) {
writeln("O" + oFormat.format(programId) + " (" + filterText(String(programComment).toUpperCase(), permittedCommentChars) + ")");
} else {
writeln("O" + oFormat.format(programId));
} else {
error(localize("Program name has not been specified."));
// dump machine configuration
var vendor = machineConfiguration.getVendor();
var model = machineConfiguration.getModel();
var description = machineConfiguration.getDescription();
if (properties.writeMachine && (vendor || model || description)) {
writeComment(localize("Machine"));
if (vendor) {
writeComment(" " + localize("vendor") + ": " + vendor);
if (model) {
writeComment(" " + localize("model") + ": " + model);
if (description) {
writeComment(" " + localize("description") + ": " + description);
// dump tool information
if (properties.writeTools) {
var zRanges = {};
if (is3D()) {
var numberOfSections = getNumberOfSections();
for (var i = 0; i < numberOfSections; ++i) {
var section = getSection(i);
var zRange = section.getGlobalZRange();
var tool = section.getTool();
if (zRanges[tool.number]) {
zRanges[tool.number].expandToRange(zRange);
} else {
zRanges[tool.number] = zRange;
var tools = getToolTable();
if (tools.getNumberOfTools() > 0) {
for (var i = 0; i < tools.getNumberOfTools(); ++i) {
var tool = tools.getTool(i);
var comment = "T" + toolFormat.format(tool.number) + " " +
"D=" + xyzFormat.format(tool.diameter) + " " +
localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
comment += " - " + getToolTypeName(tool.type);
writeComment(comment);
if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) {
for (var i = 0; i < getNumberOfSections(); ++i) {
if (getSection(i).workOffset > 0) {
error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
return;
// absolute coordinates and feed per min
writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gPlaneModal.format(17));
switch (unit) {
case IN:
writeBlock(gUnitModal.format(20));
break;
case MM:
writeBlock(gUnitModal.format(21));
break;
function onComment(message) {
writeComment(message);
/** Force output of X, Y, and Z. */
function forceXYZ() {
xOutput.reset();
yOutput.reset();
zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
aOutput.reset();
bOutput.reset();
cOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
forceXYZ();
forceABC();
feedOutput.reset();
function onParameter(name, value) {
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function setWorkPlane(abc) {
if (!machineConfiguration.isMultiAxisConfiguration()) {
return; // ignore
if (!((currentWorkPlaneABC == undefined) ||
abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) {
return; // no change
onCommand(COMMAND_UNLOCK_MULTI_AXIS);
if (!retracted) {
writeRetract(Z);
writeBlock(
gMotionModal.format(0),
conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(abc.x)),
conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(abc.y)),
conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(abc.z))
onCommand(COMMAND_LOCK_MULTI_AXIS);
currentWorkPlaneABC = abc;
var closestABC = false; // choose closest machine angles
var currentMachineABC;
function getWorkPlaneMachineABC(workPlane) {
var W = workPlane; // map to global frame
var abc = machineConfiguration.getABC(W);
if (closestABC) {
if (currentMachineABC) {
abc = machineConfiguration.remapToABC(abc, currentMachineABC);
} else {
abc = machineConfiguration.getPreferredABC(abc);
} else {
try {
abc = machineConfiguration.remapABC(abc);
currentMachineABC = abc;
} catch (e) {
error(
localize("Machine angles not supported") + ":"
+ conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x))
+ conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y))
+ conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z))
var direction = machineConfiguration.getDirection(abc);
if (!isSameDirection(direction, W.forward)) {
error(localize("Orientation not supported."));
if (!machineConfiguration.isABCSupported(abc)) {
error(
localize("Work plane is not supported") + ":"
var tcp = true;
if (tcp) {
setRotation(W); // TCP mode
} else {
var O = machineConfiguration.getOrientation(abc);
var R = machineConfiguration.getRemainingOrientation(abc, W);
setRotation(R);
return abc;
function isProbeOperation() {
return (hasParameter("operation-strategy") &&
getParameter("operation-strategy") == "probe");
function onSection() {
var insertToolCall = isFirstSection() ||
currentSection.getForceToolChange && currentSection.getForceToolChange() ||
(tool.number != getPreviousSection().getTool().number);
retracted = false;
var newWorkOffset = isFirstSection() ||
(getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
var newWorkPlane = isFirstSection() ||
!isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis()) ||
(currentSection.isOptimizedForMachine() && getPreviousSection().isOptimizedForMachine() &&
Vector.diff(getPreviousSection().getFinalToolAxisABC(), currentSection.getInitialToolAxisABC()).length > 1e-4) ||
(!machineConfiguration.isMultiAxisConfiguration() && currentSection.isMultiAxis()) ||
(!getPreviousSection().isMultiAxis() && currentSection.isMultiAxis() ||
getPreviousSection().isMultiAxis() && !currentSection.isMultiAxis()); // force newWorkPlane between indexing and simultaneous operations
if (insertToolCall || newWorkOffset || newWorkPlane) {
// retract to safe plane
writeRetract(Z);
zOutput.reset();
if (hasParameter("operation-comment")) {
var comment = getParameter("operation-comment");
if (comment) {
if (insertToolCall) {
forceWorkPlane();
setCoolant(COOLANT_OFF);
if (!isFirstSection() && properties.optionalStop) {
onCommand(COMMAND_OPTIONAL_STOP);
if (tool.number > 99) {
warning(localize("Tool number exceeds maximum value."));
writeBlock("T" + toolFormat.format(tool.number));
writeBlock(mFormat.format(6));
if (tool.comment) {
writeComment(tool.comment);
var showToolZMin = false;
if (showToolZMin) {
if (is3D()) {
var zRange = currentSection.getGlobalZRange();
var number = tool.number;
for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
if (section.getTool().number != number) {
break;
zRange.expandToRange(section.getGlobalZRange());
writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
if (properties.preloadTool) {
var nextTool = getNextTool(tool.number);
if (nextTool) {
writeBlock("T" + toolFormat.format(nextTool.number));
} else {
// preload first tool
var section = getSection(0);
var firstToolNumber = section.getTool().number;
if (tool.number != firstToolNumber) {
writeBlock("T" + toolFormat.format(firstToolNumber));
isFirstSection() ||
(rpmFormat.areDifferent(spindleSpeed, sOutput.getCurrent())) ||
(tool.clockwise != getPreviousSection().getTool().clockwise)) {
if (spindleSpeed < 1) {
error(localize("Spindle speed out of range."));
if (spindleSpeed > 99999) {
warning(localize("Spindle speed exceeds maximum value."));
var tapping = hasParameter("operation:cycleType") &&
((getParameter("operation:cycleType") == "tapping") ||
(getParameter("operation:cycleType") == "right-tapping") ||
(getParameter("operation:cycleType") == "left-tapping") ||
(getParameter("operation:cycleType") == "tapping-with-chip-breaking"));
if (!tapping || (tapping && !(properties.useRigidTapping == "without"))) {
writeBlock(
sOutput.format(spindleSpeed), mFormat.format(tool.clockwise ? 3 : 4)
// wcs
if (insertToolCall) { // force work offset when changing tool
currentWorkOffset = undefined;
var workOffset = currentSection.workOffset;
warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
workOffset = 1;
if (p <= 96) {
writeBlock(gFormat.format(54.1), "P" + p);
} else {
error(localize("Work offset out of range."));
return;
} else {
if (workOffset != currentWorkOffset) {
writeBlock(gFormat.format(53 + workOffset)); // G54->G59
currentWorkOffset = workOffset;
forceXYZ();
if (machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
// set working plane after datum shift
var abc = new Vector(0, 0, 0);
if (currentSection.isMultiAxis()) {
forceWorkPlane();
cancelTransformation();
} else {
abc = getWorkPlaneMachineABC(currentSection.workPlane);
setWorkPlane(abc);
} else { // pure 3D
var remaining = currentSection.workPlane;
if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
error(localize("Tool orientation is not supported."));
return;
setRotation(remaining);
// set coolant after we have positioned at Z
setCoolant(tool.coolant);
forceAny();
var initialPosition = getFramePosition(currentSection.getInitialPosition());
if (!retracted && !insertToolCall) {
if (getCurrentPosition().z < initialPosition.z) {
writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
if (insertToolCall || retracted) {
var lengthOffset = tool.lengthOffset;
if (lengthOffset > 99) {
error(localize("Length offset out of range."));
return;
writeBlock(gPlaneModal.format(17));
G28 G91 X0. Y0.;
useRigidTapping: {
type: "enum",
values:[
// samples:
var coolants = [
{id: COOLANT_MIST},
{id: COOLANT_AIR},
// circular output
// collected state
var sequenceNumber;
workOffset = 1;
if (p <= 300) {
} else {
return;
} else {
Output a comment.
function onOpen() {
aOutput.disable();
bOutput.disable();
cOutput.disable();
writeln("%");
if (programName) {
var programId;
try {
} catch (e) {
} else {
} else {
} else {
if (vendor) {
if (model) {
if (description) {
var zRanges = {};
if (is3D()) {
} else {
return;
switch (unit) {
case IN:
break;
case MM:
break;
xOutput.reset();
yOutput.reset();
zOutput.reset();
aOutput.reset();
bOutput.reset();
cOutput.reset();
forceXYZ();
forceABC();
feedOutput.reset();
return; // ignore
if (!retracted) {
writeRetract(Z);
writeBlock(
if (closestABC) {
} else {
} else {
try {
} catch (e) {
error(
error(
var tcp = true;
if (tcp) {
} else {
setRotation(R);
return abc;
retracted = false;
writeRetract(Z);
zOutput.reset();
if (comment) {
forceWorkPlane();
if (tool.comment) {
if (showToolZMin) {
if (is3D()) {
break;
if (nextTool) {
} else {
isFirstSection() ||
writeBlock(
// wcs
workOffset = 1;
if (p <= 96) {
} else {
return;
} else {
forceXYZ();
forceWorkPlane();
} else {
setWorkPlane(abc);
} else { // pure 3D
return;
forceAny();
return;
