Hello, I was hoping someone could explain to me how I extrude the different levels in this print with the two slots. The chaining for extrude doesn't work properly when I build it since the 3.875X1.625 box meets the slot on the radius and will not join with it. Even if it did I'm not sure how to make the 2nd and 3rd level have the 12 degree angle but not the slot. I hope that makes sense. I'm working through a book, but the chapter this is based off of doesn't explain how to build a solid with the multi-level slots. I'll drop the print in here so you can see what I'm working with. If it's too complicated to explain I perfectly understand. Thanks for looking and for any help. Much appreciated.
