need help programming z axis tool path
Results 1 to 9 of 9
    Nov 2013
    north of Bean town
    483
    78
    160
    Default need help programming z axis tool path
    Hey guys,
    I need help figuring out how to get mastercam2019 to program a xz radius.
    essentially i have a part that is a portion of an arc(think like this smiley face except the rads are parallel.
    the part is 2mm thick and i have to put a full radius on the edge(standing up in a VMC )
    Im having trouble trying to change the plane i guess?
    let me know if you need more info, ill try and post a screengrab
    Nov 2013
    north of Bean town
    483
    78
    160
    Jun 2012
    Michigan
    5,196
    4770
    3146
    Swept 2D, Swept 3D, have you tried those?
    Flowline would be my first choice.
    Morph, etc.. there are a few different ways to do this.
  4. Likes dodgin liked this post
    Mar 2015
    Michigan
    424
    95
    146
    Quote Originally Posted by Mtndew View Post
    Seconded for flowline.
    Don't need to change any planes.
    Nov 2013
    north of Bean town
    483
    78
    160
    i should also say i dont have very much experience with programming from solid, i usually draw everything and program 2D. so this flowline you speak of is an unknown. also for some reason i can only program in 3d on my olderversion X9, which isnt a problem just that im not using 2019 if it matters(im sure it does)
    I did however manage to generate a crude tool path in the way i want to go, but my notice was that the code came out in G1 moves(in x and z) and not a radial move. the arc is a true circle so i dont understand why it broke it up
    Sep 2015
    Ohio
    1,299
    860
    1301
    There should be a box to check for "use arcs"
    Sep 2007
    Washington
    5,427
    224
    1698
    You also might need to tweak your machine/control definition to allow arcs in XZ.
    Regards.
    Mike
  9. #8
    Nov 2013
    north of Bean town
    483
    78
    160
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    this is probably it, i tried the arcs settings in the operations table but no luck.
    its a small section of a 10" dia circle(like 16deg of it) so i think i can use the G1 if i cant get a radial value...probably just have to blend with some paper..did i mention its Inco625
  10. #9
    Southern Indiana USA
    171
    19
    79
    G18 allows circular interpolation in the XZ plane.
