One Machine Acting Differently
Results 1 to 17 of 17
    Sep 2019
    Colorado
    Default One Machine Acting Differently
    Hello,
    We have eight Haas VF2 vertical mills, with TR160 trunnions. We feed every one of the mills with the same CAM software, using the same machine definition. This allows the operators to grab a job and put it into any open machine. When comparing machines, every trunnions platter is within .005" from the centerline of A rotation, from one machine to the next. Every one I've measured is within Haas's specifications. We do most of our milling with the platter perpendicular to the table. When one machine indexes ninety degrees from there, (platter parallel to table) its Z is off, and it mills holes through the units. If we take that code and put it on any other mill it runs fine. The only immediate solution I see is to assign another WCS, but that would create 100% more work for the programming department. We are using HyperDent, and utilizing feature based machining. This is VERY scaled down CAM software that doesn't give the programmers control like Mastercam offers. So if we were to implement another WCS that would be written into every program. The programmers would then have to combine NC files because they would be too large for HyperDent to handle. This is not a viable solution for us. Where would you start trying to diagnose this problem?
    Jan 2007
    Flushing/Flint, Michigan
    7,726
    385
    6440
    Five thou is a lot but how far off are you blowing the Z by at flat?
    +90 and zero are the only used positions?
    XY are okay at both and only Z the problem?
    Bob
    Jan 2015
    704
    104
    365
    ....WHAT?
    It would help if you could clearly define the actual problem? This makes no sense.
    Quote Originally Posted by NOStrum View Post
    Sounds fine so far. Assuming you're talking about the y-center of platter in relation to tilt axis?
    So at A90.?
    What? 90° which way? A0? A180? or you trying to say A90 or C(B?)90?
    Holes through what units? The rotary unit? Workpiece? What?
    Are you really talking about the rotary platter, or are you referencing some kind of fixture?
    Perhaps some pictures would help
    Jan 2014
    Temecula, Ca
    2,824
    1269
    3657
    I would measure the Z heights of all the trunions, then grind the high ones down to match the lowest one.
    Sep 2009
    barcelona, spain
    2,381
    530
    1431
    Imo.
    It´s a specific bug/feature related to your setup.
    Use any form of bump by offset of something until it goes away.
    The bug is not necessarily related to rotaries, could be tools, or tooltip compensation, or anything.
    Try adding 0.001" to everything-comp and see if it changes.
    Hello,
    Sep 2019
    Colorado
    Correct Bob. The Z is off when the trunnion goes to A90.
    We aren't milling aerospace. .005" is plenty for us. It's overmilling by over .1" though.
    Bob
    Sep 2019
    Colorado
    From centerline of A to platter face (when parallel with table) are all within .005" from one machine to the next. So this is not our problem. Although grinding everything the same would be ideal.
    Feb 2006
    Ontario, Canada
    817
    36
    108
    I can't speak directly about your machines, but on our Hermle machines with Heidenhain controllers there is a function to adjust the kinematics of the machine so that the controller calculates correctly regardless of the actual position of the individual machine components. So if you had a hard hit you can run this test to bring the machine back to it's maximum accuracy. Perhaps Haas has something similar?
    Sep 2002
    People's Republic
    3,011
    217
    2073
    This is way above my pay grade, but if I were faced with a similar issue the two things I could think of doing
    1] download all the machine parameters and since they ought to be text files there are several ways to compare them. Look at the results and consider what you see. IS there a orientation or Z related difference?
    2] look at the way the tool length offset is set. Is it in some way different on this machine than the others? For instance what is the actual distance from the spindle nose to the trunnion surface with tool zero, or no compensation compared to the other machines. I cannot for the life of me think of why it would be different in one orientation than another, but something is different in different orientations
    It would seem to me that it is either machine side, IE parameters, or user side IE tool setup. If it is something else, you are in deep doo doo...
    Jan 2014
    Temecula, Ca
    2,824
    1269
    3657
    without any pictures, and without any clear description, I'm going to say it's just a fucked up setup.
  11. Likes Mtndew, thesidetalker liked this post
  12. #11
    Feb 2013
    Idaho
    669
    139
    717
    Anytime I see an error of .100” I assume someone screwed up with an edgefinder
    How were the machines set-up originally? I generally sweep the platter flat for A zero. Then rotate to A90 and edge find my first Y. Rotate to A-90 and find my second Y. The difference between these two Ys times .5 is the difference between platen height and the A axis of rotation. On the TR160, the A axis center of rotation should be ~.120” above the platter. The way I program, that is how I set my Z0 (a single G54 for all operations).
    However, if the Z offset was incorrect, you would have the same error on the operations that you do at A90... holes and features would be too deep (assuming you are using a single G54).
    I almost wonder if that one machine has Dynamic Work Offsets and Tool Center Point Control turned on and that is causing the conflict. I don’t use it, so I’m not familiar with the ins and outs... other than it alters the interpretation of the code to alter the position in space.
  13. #12
    Jun 2012
    Michigan
    4,643
    4248
    2803
    Ok you can rule out the cad or program, and start looking at parameters or taking a closer look at the fucked up machine/trunnion. Either that was initially set wrong, it's a different height, different location, or you have a parameter different than the rest.
  14. Likes Larry Dickman liked this post
  15. #13
    Sep 2005
    Oakland, CA
    2,440
    259
    650
    Where is the platter when you do a -90 move compared to a +90 move? oh- I see GOO asked the same question.
  16. #14
    Jan 2005
    CANADA
    Saskatchewan
    10,222
    1392
    3674
    Sounds to me like the Y offset for that platter's work offset is incorrect. That becomes a Z error when the platter is rotated.
  17. Likes bryan_machine liked this post
  18. #15
    Oct 2012
    Orange county, CA
    99
    6
    22
    ya that's an offsetting problem. Are you using dynamic work offsetting? have you checked the platter with an MRZP calibration? I'm assuming these machines have probes...
  19. #16
    Jan 2014
    Temecula, Ca
    2,824
    1269
    3657
    doesn't sound like we're ever going to find out.
  20. #17
    May 2017
    Minnesota
    990
    1192
    613
    When you say you measured the point of rotation and the platter height, is that relative to the table or to machine zero? Are the machines set up with the machine zero at the same height off the table?
