what are the disadvantages of Bobcadcam ?
Richard,
The biggest problem with Bobcad is that they continue to release new versions of their product that are full of bugs. Once the product is on the market, they make little or no effort to correct known bugs. It's my opinion that they use this as a selling tool for their "support", but I can tell you from personal experience that their support is absolutely useless, unless one considers answers like "we've never had that problem before" or "we'll check that out and get back to you" (which they never do) as being a viable system of product support worth paying for. The vast majority of people who have dealt with Bobcad (myself included) find the organization to be neither credible nor honest in selling their products.
The head guy of Bobcad shills regularly at CNCZone, and I readily admit to having taken great pleasure more than once in thoroughly pissing him off by pointing out inaccurate information or outright lies he's posted regarding what he's selling. Since he's a paying advertiser there, he has, in every instance, requested the administrator to shut down the thread instead of making any attempt to defend what he has said. I would add that others have done the same thing and have gotten the same results. For that reason CNCZone, IMO, has no credibility whatsoever either, since it operates as a puppet front for its paying advertisers.
You've mentioned Bobcad 17 recently here. For a good example of how it screws up the most basic of operations, just try this.....create a set of points representing a bolt pattern. Sketched points are fine, and they don't have to be in any specific pattern. Also create a point at X-1,Y0 to be used as a point to move to later. Now open the cam side of the program and do a G81 drill routine, either by preselecting the points via edit or by clicking on them individually once G81 is invoked. Make sure the tooltip display button is on, as this tooltip is where the program thinks it is, and it generates its next move based on where it thinks it is. Run the drill cycle on some number of your points. Now click on the drill cycles and do a G80 to cancel the canned cycle. Watch when you click to enter the G80 into the code as the tooltip pops back to the origin, but look also at the code and you'll see no indication of a move taking you back to the origin. Now, click on the "move to point" button, and select the X-1Y0 point as your point to move to. Look now at the code, and you'll see a G0 X-1 has been added to the code, and the tooltip will be at this location. But, when you examine the code, you'll find that the tool is actually going to move to X-1, but the Y location is going to still be the same as the Y location of the last hole you drilled. Had this point been at some Y location other than zero, the code would have been correct, but that is immaterial as it would have been correct by accident. The program thinks it's at 0,0 once you invoke G80 even though its not. This is but one of a number of problems with Bobcad, and although 17 has been on the market for 5+ years, to my knowledge it has never been fixed even though they're still selling the software today. For that particular problem, the only work-around I know of is to go into the setup-custom box and create a menu item for G80 and use it to cancel canned cycles instead of using the G80 in the canned cycle box. Now for the worst news....for all its shortcomings, V17 is a much more reliable program than either V18 or V19. V19 is in at least its 8th release, with some of the releases actually having more new bugs than the number of old ones they fixed. Just got an email this morning announcing the release of V20, and I'd certainly have no reason to think it's anything but worse since it looks more complex. Lots of things in various internet venues would indicate Bobcad is on the ropes and won't be with us much longer. They certainly don't deserve to survive IMO.
