Optional stops in Fusion360
Results 1 to 12 of 12
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Default Optional stops in Fusion360
    I use F360 to program my plasma table. It works very well except that my table has no probing function and a semi-crappy THC. I'd like to program an M1 before every M3 so that I may verify Z height before the pierce. I know this sounds like hobbyist bullshit, but the table basically prints money as is so I'm gonna milk it.
    I realize I can make each cut a new op and then add a stop in between, but I was wondering if there was a better way.
    Thanks, Cole
    Jun 2012
    Davis Junction, Illinois
    152
    45
    23
    Add it to the post.
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Quote Originally Posted by Archer120x View Post
    Add it to the post.
    Could you elaborate? I've never edited a post like this.
    Jan 2019
    Tennessee
    456
    139
    120
    hypertherm command thc is semi crappy thc, one that can not touch off is full crappy- just fly blind and fast at that point.
    Jun 2012
    152
    45
    23
    There's a bunch of information and videos on fusion 360 post editing if you google it. Your need is actually a good place to start. Basically, everywhere the post inserts an M03, add the code to insert a M01.
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Quote Originally Posted by memphisjed View Post
    In all reality, it's probably just my ignorance on how to program the G31 in Mach 3. F360 outputs the code but I haven't figured out how to really set that up. I thought I could use the 'arc on' circuit of the THC as a probe signal, but I don't think I am doing it right.
    Jan 2019
    Tennessee
    456
    139
    120
    have a macro move z (torch) down until it touches plate. this is a 12 volt(5 would work) supplied to torch shield, use extra limit switch port/receive signal. once circuit is closed have macro move torch up +200% of cut height turn off signal power. use a relay to sever signal power and controller. then arc on, dwell (pierce), then lower torch to cut height or have thc take control.
    every thc has some voodoo that does something like this. Hypertherm uses encoder on stepper to since missed steps as contact height. You could use a spindle sync encoder pin out to mimic same in mach I think. but mach, maybe it is not your height controllers fault.
    valk/hornet/controlled/komitsu all use servo torque feed back.
  8. Likes g-coder05 liked this post
  9. #8
    Jul 2010
    eugene,or
    848
    86
    353
    +1 Fusion 360 posts are easy to edit. It's written in JavaScript which is a pretty easy language to learn.
    Sent from my XT1710-02 using Tapatalk
  10. #9
    May 2019
    317
    78
    104
    Quote Originally Posted by Cole2534 View Post
    Thanks, Cole
    Personally I would add torch probing rather than creating a work around to a problem. I built a probing setup long before I built a THC as its a simple setup. Mount your torch on a linear rail that is spring loaded with a limit switch. Wire it up and enter your offsets and you are done. You can also go the ohmic route but tuning is a little more difficult and in my experience speed is a little slower. I probe at 50 ipm (I could probably go faster but I only run a 1" safe z so 50 ipm gets there pretty quickly). Once your piece is complete your THC should take over
  11. #10
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Hardplates is right, I'll look more into the probing.
  12. #11
    Sep 2017
    Wisconsin
    593
    81
    293
    You can also just add "Manual NC" operations into your setup right in the Manufacture environment in F360. Optional Stop is already in the default list. You can find it in the "Setup" dropdown.
  13. #12
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Quote Originally Posted by Rick Finsta View Post
    That's what I had been doing. Thank you for the reminder though.
