SeymourDumore
- Aug 2, 2005
- CT
Wheelie ( or anyone else who might know )
In the past you were bitchin' about something that the newer releases of FC does ( or does not ) do to the toolcrib.
Well, up until 3 months ago, I was on V2015 and had no issues.
Now that I am finally on 2020, all of a sudden have a weird problem.
I have my toolcrib, and it is properly populated with what I want, have, need. ( Seymour-toolcrib)
In the program settings, it is properly defaulted that new programs use the Seymour-toolcrib
In the program settings, It is also set that the toolcrib is saved with the program. ( the FM file )
This has worked flawlessly for the last 14 years.
New part is opened, toolcrib is populated from Seymour-toolcrib, given the name of the FM file and is saved in its entirety in the FM file.
Not only the tools used for the program, but the whole thing as-imported from Seymour-toolcrib.
Now however, Some Freakin' Time the only tools that are saved in the FM file are the ones used for the part!!!
Not all the time, but perhaps 1 or 2 out of 10!!!
It is getting to be PITA to have to re-select the default toolcrib every time the file is opened and new toolpaths are created.
Is this what you've had issues with, and if yes, did you ever figure out a solution?
Thank You
Thank You
