Powermill internal SFM Calculator
TheTalman1
Jun 21, 2018
Hey all, Noticed a bit of a discrepancy using the internal Feeds and speeds calculator on Powermill 17 as follows.
Powermill input
1" Dia. Tool 4Fl
30 SFM
.003 IPT
Powermill outputs
573 RPM
7.16 IPM
By hand
3.82*30/1=114.6 RPM
114.6*.003*4=1.375 IPM
Quite a bit of difference there anyone else use this software and noticed it/fixed it?
Figured it out, this was someone elses project that I took over and he had a box ticked on the speeds and feeds of 3 or 4 processes out about 20. The box is called "Working Diameter" and he had it set at 1" DOC with a 0 degree angle which spit out some really wonky numbers. Would have welded the cutter to this 316SS. I believe this is meant more for use with finishing slopes with ball nosed tools.
