Problem with Fusion360 on Haas machine... Z height to start is too low.
Results 1 to 9 of 9
    Nov 2020
    North Carolina
    16
    Default Problem with Fusion360 on Haas machine... Z height to start is too low.
    I've run into a problem and I can't figure it out. And of course I am under the gun on a deadline.
    Using Fusion360 I have a CAM file to drill some holes in a part. The part is tall, and the drill is long.
    On the Haas I have my tool loaded (T3) and it is ABOVE my part and to the left (+x). G54 is set correctly at the TOP of the part.
    But as soon as I Cycle Start it lowers the drill and start moving X positive... and it's going to crash. I've caught it and stared at my code, but I can't see why it is lowering the tool below the clearance/retract/feed heights.
    Here's my .nc file:
    And pasted is a screen shot of the heights tab.
    Any ideas?
    I can upload a video if that helps, but it's fairly straight forward. First thing the Haas does is lower the Z. Then start moving left.
    O62302 (Drill Final)
    (Using high feed G1 F500. instead of G0.)
    (T3 D=0.4375 CR=0. TAPER=118deg - ZMIN=-1.2314 - drill)
    N10 G90 G94 G17
    N15 G20
    N20 G53 G0 Z0.
    (Drill29 2)
    N25 T3 M6
    N30 S900 M3
    N35 G54
    N40 M8
    N45 G0 X4.25 Y3.969
    N50 G43 Z1.25 H3
    N55 G0 Z0.6
    N60 G98 G83 X4.25 Y3.969 Z-1.2314 R0.6 Q0.1 F4.
    N65 Y0.469
    N70 Y-0.469
    N75 Y-3.969
    N80 X-4.25
    N85 Y-0.469
    N90 Y0.469
    N95 Y3.969
    N100 G80
    N105 G0 Z1.25
    N110 M5
    N115 M9
    N120 G53 G0 Z0.
    N125 X0.
    N130 G53 G0 Y0.
    N135 M30
    Attached Thumbnails Attached Thumbnails screen-shot-2021-06-24-12.03.53-am.jpg
    Feb 2019
    New York
    552
    555
    Nothing wrong with that program, make sure your "H" offset is set correctly
    Dec 2018
    241
    628
    69
    Code looks fine. There has to be a problem with you not touching off the tool correctly or G54 not setup correctly.
    Sep 2009
    PA
    1,504
    200
    429
    Quote Originally Posted by HappyHapgood View Post
    Here's my .nc file:
    Any ideas?
    N10 G90 G94 G17
    N15 G20
    N20 G53 G0 Z0.
    (Drill29 2)
    N25 T3 M6
    N30 S900 M3
    N35 G54
    N40 M8
    N45 G0 X4.25 Y3.969
    N50 G43 Z1.25 H3
    N55 G0 Z0.6
    N65 Y0.469
    N70 Y-0.469
    N75 Y-3.969
    N80 X-4.25
    N85 Y-0.469
    N90 Y0.469
    N95 Y3.969
    N100 G80
    N105 G0 Z1.25
    N110 M5
    N115 M9
    N120 G53 G0 Z0.
    N125 X0.
    N130 G53 G0 Y0.
    N135 M30
    Have you tried this in single block. I assume the head is dropping on the G53 Z0 line. Likely you just don't have enough travel. I believe G53 z0 is below the max z height the machine can travel. In MDI crank the head up as far as it will go and command the G53 z0 and see if the head drops
  5. Likes toolsteel liked this post
    Nov 2012
    Wisconsin
    2,338
    3864
    2890
    Aug 2005
    CT
    8,533
    487
    2304
    Unless I misunderstood your problem, what's up with this:
    (Drill29 2)
    N25 T3 M6
    N30 S900 M3
    N35 G54
    N40 M8
    N45 G0 X4.25 Y3.969
    N50 G43 Z1.25 H3 <------????
    How' bout this instead:
    (Drill29 2)
    T3 M6
    G00 G43 H03 D03 (<-------!!!!)
    S900 M3
    G54
    N40 M8
    G00 Z1.25 (<-----!!!)
    G0 X4.25 Y3.969
    IOW, you were moving in X and Y before activating the length offset.
    If you are normally doing it that way, I guess the machine won't bitch and it won't be an issue with collision if there is enough albow room in Z.
    Now that the part is tall and tool is long, you've just got bitten in the ass for a perfectly good reason!
    I absolutely do not understand why would anyone not activate length and dia BEFORE any movement!
    My standard SOP is:
    Tx M06
    G00 G43 Hx Dx
    always always always always ....
  8. Likes gkoenig liked this post
  9. #7
    Nov 2020
    North Carolina
    16
    It's dropping PRIOR to the N45 line. Then starts to move sideways into the work. That's what I don't understand. I'll try your recommendation.
    And sorry to you and the others who replied... I've been so under the gun that I haven't typed replies. I have been working with someone from Phillips Corp (Haas vendor) and not yet resolved it either. I ended up manually doing the drilling with the machine (just annoying because can't peck and I had a BUNCH of them to do.
    Quote Originally Posted by csharp View Post
  10. #8
    Nov 2020
    North Carolina
    16
    Really good point. As you may have noticed... I am not very experienced and still learning. I appreciate your clear guidance and will try this over the weekend.
    Unfortunately, my compressor crapped out yesterday (fortunately, I finished the job right as it was dying. Kinda humorous... I think it literally threw a rod. Made a most god-awful racket for about ten minutes (I was too desperate to finish the job to shut it down and after about 10 minutes it slowly quieted down. Figure it ate a rod or something. I'll be disassembling it this weekend to see if it's salvageable. It was a cheap unit that lasted 35 years so probably time to replace it anyway.
  11. #9
    Nov 2020
    North Carolina
    16
    Yup. Threw a rod. Wedged a piston. Tore up the fan. But now fully overhauled and back to being very mediocre!
