Programming multiple parts per fixture
Page 1 of 2 12 LastLast
Results 1 to 20 of 38
    Sep 2010
    Oklahoma City, OK
    5,343
    1001
    2312
    Default Programming multiple parts per fixture
    Hello,
    I suspect this comes down to a mixture of personal preference and resource limitations but I wanted to ask anyway.
    If you're milling multiple identical pieces per fixture, do you program each piece as a new fixture offset or set the fixture as one offset and have multiple entities in the model? It seems like the biggest decision is whether you want to make individual tweaks in the control or in the model, but maybe I'm missing something.
    Are there distinct advantages to either method and which do you prefer?
    Nov 2014
    Florida
    5,908
    2329
    2927
    Quote Originally Posted by Cole2534 View Post
    Hello,
    I use a combination of both. For example, might lay out multiple pieces for a sanity check, then program one face pass (for example) setting stock up for G54 only. Then I might transform the spot/hole drilling ops. Depends entirely on part and features IMO.
    Sep 2010
    Oklahoma City, OK
    5,343
    1001
    2312
    Reason for my Q was that I need to drill/tap Al bars in the vise, no critical features or dims. In the manual mill I'd line them up, locate one hole, and then offset by the spacing. In the CNC, the vise is already a fixture so just model up however many pieces fit in the vise, or do them individually.
    I think it depends on how picky the parts are, I'd rather make individual tweaks for location in the control rather than the model.
  4. Likes cmainman liked this post
    Dec 2008
    New York
    10,398
    2711
    advantage with a different work offset for each part is when each part is probed and different work offset used for each part. the probing can get exact location on specific features like a bore or specific surfaces
    ....often parts spaced the spacing is not exact and can vary .001 to .010" if edge locators are not exact in position or torque used not exactly the same or even uneven temperature control, probing will give a more exact current position of specific features
    Jun 2012
    Michigan
    5,563
    5245
    3542
    It depends really.
    Are these 1st op parts where you're qualifying the outside to make sure the holes will be in location?
    Or are they 2nd op parts where a finished edge is up against a stop?
    If you're locating a finished edge up against a stop I would go with separate work offsets.
    If it's raw stock, just 1 offset will suffice.
    I do both, sometimes in the situation above, or how I'm feeling that day.
  7. Likes AARONT, wheelieking71 liked this post
  8. #6
    Jul 2012
    Washington
    3,301
    1339
    1445
    As long as the quantities support it I always program 1 or 4 parts then shift the coordinate system to make more, usually with fixture offsets. Of course, the best answer to your question is "it depends". For lower quantites I just make one part at a time since I make them on a fast drill/tap mill, another important detail to how to program is what are you programming for.
  9. #7
    Feb 2013
    Madison, WI
    1,197
    1250
    773
    Personally I like to use a separate work offset for each part. Just because I like to have the most control over my parts. But as stated above if it's the first op it's usually not an issue to just pattern out the toolpaths on the CAM side.
  10. Likes Rstewart liked this post
  11. #8
    Sep 2017
    Wisconsin
    1,129
    273
    739
    If I am cutting fixtures (or soft jaws) and putting the parts in them, then I'll use pattern outputs from CAM and a single WCS zero since the machine will repeat. If it is something like vise work I use multiple WCS. If I have probing this also changes things since I will generally probe certain types of features on a machine that won't be slowed down much by it (Speedio, Robodrill, etc.) for vise work.
  12. #9
    Sep 2010
    Oklahoma City, OK
    5,343
    1001
    2312
    Quote Originally Posted by DavidScott View Post
    I usually do that, but I'm trying to train myself to step back from the machine so I can multitask.
  13. #10
    Sep 2008
    Florida
    374
    30
    99
    You also could try G52 local coordinate system with each shift calling a subprogram for each machining operation. Only have to set one work offset that way, and spacing can be easily altered by the value on the G52 line.
  14. #11
    Jun 2019
    South Carolina
    Generally speaking, I use a different coordinate system for each loose piece of material. If I am making 2pcs. from one block then they will be modeled and programmed together in one system.
    Sent from my SM-J737V using Tapatalk
  15. #12
    Sep 2013
    Minnesota
    342
    130
    84
    When I program multiple parts I like to use a MCS for each part unless multiples are being milled from one block, as cmainman mentioned. It is desirable to use multiple MCS if you are nesting parts with multiple orientations and non-nominal spacing. In those cases it's nice to have your cam system use one program and apply to to all MCS's regardless of how and where the part are situated and still be able to do full tool path checking and simulation. The icing on the cake is the ability to deviate from instanced tool paths and tweak individual parts if needed but still have full associativity and be able to revert back to the instanced paths if needed. I love that feature of NX. On a tangent, another cool feature which comes in handy is the ability to use an IPW (stock model for the MC guys) on various parts with MCS's all over the place. Again with full associativity, gouge checking and simulation.
  16. #13
    Sep 2002
    People's Republic
    5,638
    671
    3508
    I vote for compact code, one program called multiple times with datum shifts or offsets or whatever. It ensures that the same code is run on each part.
  17. Likes cmainman, TeachMePlease, Rstewart liked this post
  18. #14
    Jun 2015
    Minnesota
    659
    12
    226
    I concur. Also safer. One local drawing. One local program. Once proofed you can dance it around the stock and/or machine any way you want using on the fly G10 offset changes or simple work coordinate changes or both. I'll create programs that have all the additional part program calls block skipped out. Button in... one part. Button out... many parts.
    Dave
  19. Likes cmainman, gmoushon liked this post
  20. #15
    May 2018
    New York
    175
    130
    91
    Keep in mind the amount of tool changes with some of these suggestions.
  21. Likes wheelieking71 liked this post
  22. #16
    Jan 2015
    816
    121
    420
    Quote Originally Posted by Rick Finsta View Post
    I do the same. Both ways depending on the setup or qty. Multiple or perhaps different vises I program one part and the post spits out sub calls and separate WCS for each.
    Dedicated fixture? Array or pattern in CAM and make it one big program. One offset per group of parts.
    Quote Originally Posted by Jmaks View Post
    Either way you can still minimize toolchanges. In both methods each tool is run through the whole lot, before changing to next tool.
  23. #17
    Jun 2015
    Minnesota
    659
    12
    226
    The program style I speak of has the exact same amount of tool changes regardless of how many parts. The block skipped blocks that call for additional offsets or parts to be made are included in each tools' programming.
    Dave
  24. Likes Jmaks liked this post
  25. #18
    Sep 2002
    People's Republic
    5,638
    671
    3508
    absolutely
    It does depend on machine tool change time, but most of my programs consist of a series of subprograms then datums shifts and label calls[heidenhain speak]
    I tend to write them as a single position then label them after so the program rarely begins at block 1, just a note at the beginning saying 'starts ad block 456'
    keeps it so I can run one part if need be.
  26. #19
    Apr 2013
    South Australia
    457
    122
    148
    Depends on the machine as well. In Mazatrol you can set up multiple pieces at the start of the program Then prioritize the tools to save on tool changes. Works great for me
  27. #20
    Feb 2012
    1,489
    921
    1665
    Pros:
    - Fewer tool changes
    - Potentially less air cutting from fewer lead-ins/outs
    - Easier to re-run finishing ops for high accuracy features
    - Higher density fixtures are possible
    Cons:
    - Tweaking programs in CAM may require reselecting a lot of geometry
    - Programs can be much longer, a problem if your machines are memory-limited
    - Proving out programs can be tiresome (babysitting a much longer cycle)
    So we split the difference.
    On a 4-sided tombstone in an HMC, running identical parts on all faces and multiple parts per face, we machine all identical parts on one face simultaneously. Then index 90, run again, rinse and repeat.
  28. Likes mbraddock liked this post
