Question about Mastercam lathe strategy. Not digging the toolpaths.
Results 1 to 8 of 8
    Feb 2014
    UT
    553
    102
    Default Question about Mastercam lathe strategy. Not digging the toolpaths.
    I had to run a quick job on our 2 axis Fanuc lathe and programmed it with X5. I am wondering if anyone else has had issues with chipping inserts with these paths? It could be in the way I am generating them by selecting the radius and the OD line. Is there a better method? I think this is sort of like how an endmill can overload in a corner. The path comes in axially, then turns and follows the contour towards the OD.
    Just curious how you guys do this stuff? Obviously this is pretty basic so hand coding could work but I prefer CAM for everything so we have a good record and can move to another machine if needed.
    Jun 2011
    Georgetown, TX
    375
    66
    61
    Used the Mcam toolpaths for decades now, no issues. Look at your DOC and make sure the tool is solid.
    CNC Software hasnt made any real changes in forever, so if it's not working look at your settings.
    Nov 2007
    canada
    703
    93
    375
    Without more context, tough to figure out your problem...but no, it's not the CAM to blame. A G01 Z-x.xxxx Fx.xxx is the same in any software. Post the code, show the stock, and maybe we could help.
    Jul 2013
    Indiana
    3,200
    4693
    1619
    I know almost nothing about the lathe part of MasterCam but still I'm sitting here wondering what in the world would make you think this is because of the toolpath?
    I've looked at the picture and it doesn't appear that anything is happening that wouldn't happen in a Fanuc turning canned cycle.
    If this is the chatter part from the other day I'd be more inclined to think its something to do with the holder or insert itself again. Or maybe the vibration you mentioned if you're still having it?
    Brent
  5. Likes Mtndew liked this post
    May 2017
    Minnesota
    968
    1174
    602
    If you want to change the lead-in direction, speed, length etc. you can do that in Mastercam.
    Nov 2014
    Florida
    3,605
    1510
    1709
    Quote Originally Posted by huleo View Post
    Is the smaller od already machined? If not, yes your tool is probably plunging into material there. I am not sure what you mean "radius and OD". I have always selected the entire contour (chain) I want to cut. For that part you show I would have picked the far right end at the beginning (smallest od) of that end radius, then followed all the way to where the end is on left side.
    On a side note, I know some people don't know (see?) the little checbox in the lower right corner for stock. You have some options there you might want to look at.
    Dec 2014
    163
    17
    28
    I'm not sure what your problem is. Since you don't have much turning experience its hard to explain the problem - understandable. Will take a guess like everyone else.
    I think your geometry is not good. I'm guessing you are not liking all the moves (or there is a rapid) on that radius. You probably used the lathe profile tool with the spin option set to .001. Use .0001 or use the "slice" option.
    to fix that geometry, delete all the line segments by drawing a window over that area and hitting delete key. Now fix the geomety with the wireframe create radius tool. Now rechain and you will gave better geo.
    Basic mcam lathe toolpaths have an incredible amount of options, they will not be your source of trouble.
  9. #8
    Dec 2014
    163
    17
    28
    Looking at it again the toolpath looks pretty good. Increase your depth of cut if you want less radius cuts. Its' doing what you are telling it to do, that large radius requires depth cuts.
    If you do not want them just use a finish toolpath and use the "finish step over" section.
