smallshop
- Jun 2, 2005
- North Central Montana
Does any one know which cam systems will run 2.5 and 3d toolpaths on and stl file? I tried it with VisualMill and had no problems. Is it a misconception that most cam packages won't cut an stl file? We get questions from potential customers interested in buying the Nextengine 3d scanner about this and one individual posted on a blog about it being a "non machinable file". RhinoCam seems to be able to do almost as much with a mesh as a nurbs surface. I haven't tried everything but I'm not seeing the problem.I would think most cam packages are the same here? If you know specifically that your cam package will cut an stl file or what the limitations are please reply.
Ted
Ted
