I've used 2020 for quite sometime and have pretty good luck with it. Was told by rep. that "2022 was basically the same", it's not. Manipulating the solid is a lot harder and infinitely more frustrating.
1) on the old mastercam you would remove a feature pretty easily and have it fill in the hole, the step, etc. the new one errors out very easily with "parasolid kernel error" or it just says "could not complete body creation or feature removal "
2) in cases where 2020 couldn't remove a feature, you could push/pull on your step/face until it matched an adjacent surface in height and the step would disappear, on 2022 it leaves the dividing line between the features and treats it as 2 separate faces. I tried " remove face" and it just screws up the model.
3) when you do manage to have it remove a feature , like the hole on the left/top, it doesn't really remove it. Similar to problem 2, it fills in the hole, and treats the model as a unified solid, but pushing puling on the face it's still a separate body. I tried Boolean/Add, but it doesn't see the problem and treats it as a single solid.
Please help, i can't open the file with my old Mastercam 2020 and this thing is kicking my a**
