And the second half:
if (machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
// set working plane after datum shift
var abc = new Vector(0, 0, 0);
if (currentSection.isMultiAxis()) {
cancelTransformation();
} else {
abc = getWorkPlaneMachineABC(currentSection.workPlane);
setWorkPlane(abc);
} else { // pure 3D
var remaining = currentSection.workPlane;
if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
error(localize("Tool orientation is not supported."));
return;
setRotation(remaining);
// set coolant after we have positioned at Z
var c = mapCoolantTable.lookup(tool.coolant);
if (c) {
writeBlock(mFormat.format(c));
} else {
warning(localize("Coolant not supported."));
forceAny();
gMotionModal.reset();
var initialPosition = getFramePosition(currentSection.getInitialPosition());
if (!retracted && !insertToolCall) {
if (getCurrentPosition().z < initialPosition.z) {
writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
if (insertToolCall || retracted) {
var lengthOffset = tool.lengthOffset;
if (lengthOffset > 200) {
error(localize("Length offset out of range."));
return;
writeBlock(gPlaneModal.format(17));
if (!machineConfiguration.isHeadConfiguration()) {
writeBlock(
gAbsIncModal.format(90),
gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
writeBlock(gMotionModal.format(0), gFormat.format(43), zOutput.format(initialPosition.z), hFormat.format(lengthOffset));
} else {
writeBlock(
gFormat.format(43), xOutput.format(initialPosition.x),
yOutput.format(initialPosition.y),
} else {
writeBlock(
function onDwell(seconds) {
if (seconds > 99999.999) {
warning(localize("Dwelling time is out of range."));
milliseconds = clamp(1, seconds * 1000, 99999999);
writeBlock(gFormat.format(4), "P" + milliFormat.format(milliseconds));
function onSpindleSpeed(spindleSpeed) {
writeBlock(sOutput.format(spindleSpeed));
function onCycle() {
function getCommonCycle(x, y, z, r) {
forceXYZ();
return [xOutput.format(x), yOutput.format
zOutput.format(z),
"R" + xyzFormat.format(r)];
function onCyclePoint(x, y, z) {
if (isFirstCyclePoint()) {
repositionToCycleClearance(cycle, x, y, z);
// return to initial Z which is clearance plane and set absolute mode
var F = cycle.feedrate;
var P = !cycle.dwell ? 0 : clamp(1, cycle.dwell * 1000, 99999999); // in milliseconds
switch (cycleType) {
case "drilling":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(81),
getCommonCycle(x, y, z, cycle.retract),
feedOutput.format(F)
break;
case "counter-boring":
if (P > 0) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(82),
"P" + milliFormat.format(P),
} else {
writeBlock(
break;
case "chip-breaking":
// cycle.accumulatedDepth is ignored
if (P > 0) {
expandCyclePoint(x, y, z);
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(73),
"Q" + xyzFormat.format(cycle.incrementalDepth),
break;
case "deep-drilling":
if (P > 0) {
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83),
// conditional(P > 0, "P" + milliFormat.format(P)),
break;
case "tapping":
if (!F) {
F = tool.getThreadPitch();
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND) ? 74 : 84),
"F" + xyzFormat.format(tool.getThreadPitch())
break;
case "left-tapping":
if (!F) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(74),
break;
case "right-tapping":
if (!F) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(84), gFeedModeModal.format(95),
break;
case "fine-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(76),
"P" + milliFormat.format(P), // not optional
"Q" + xyzFormat.format(cycle.shift),
break;
case "back-boring":
var dx = (gPlaneModal.getCurrent() == 19) ? cycle.backBoreDistance : 0;
var dy = (gPlaneModal.getCurrent() == 18) ? cycle.backBoreDistance : 0;
var dz = (gPlaneModal.getCurrent() == 17) ? cycle.backBoreDistance : 0;
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(87),
getCommonCycle(x - dx, y - dy, z - dz, cycle.bottom),
"I" + xyzFormat.format(cycle.shift),
"J" + xyzFormat.format(0),
break;
case "reaming":
if (P > 0) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(89),
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(85),
break;
case "stop-boring":
if (P > 0) {
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(86),
break;
case "manual-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(88),
break;
case "boring":
if (P > 0) {
writeBlock(
} else {
writeBlock(
break;
default:
} else {
if (cycleExpanded) {
} else {
writeBlock(xOutput.format(x), yOutput.format
function onCycleEnd() {
if (!cycleExpanded) {
writeBlock( gCycleModal.format(80), gFeedModeModal.format(94)
zOutput.reset();
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
var x = xOutput.format(_x);
var y = yOutput.format(_y);
var z = zOutput.format(_z);
if (x || y || z) {
if (pendingRadiusCompensation >= 0) {
error(localize("Radius compensation mode cannot be changed at rapid traversal."));
writeBlock(gMotionModal.format(0), x, y, z);
feedOutput.reset();
function onLinear(_x, _y, _z, feed) {
var f = feedOutput.format(feed);
if (x || y || z) {
var d = tool.diameterOffset;
if (d > 200) {
warning(localize("The diameter offset exceeds the maximum value."));
switch (radiusCompensation) {
case RADIUS_COMPENSATION_LEFT:
dOutput.reset();
writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, dOutput.format(d), f);
break;
case RADIUS_COMPENSATION_RIGHT:
dOutput.reset();
writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, dOutput.format(d), f);
break;
default:
writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
} else {
writeBlock(gMotionModal.format(1), x, y, z, f);
} else if (f) {
if (getNextRecord().isMotion()) { // try not to output feed without motion
feedOutput.reset(); // force feed on next line
} else {
writeBlock(gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
if (!currentSection.isOptimizedForMachine()) {
error(localize("This post configuration has not been customized for 5-axis simultaneous toolpath."));
return;
return;
var a = aOutput.format(_a);
var b = bOutput.format(_b);
var c = cOutput.format(_c);
writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
feedOutput.reset();
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
return;
error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
return;
if (x || y || z || a || b || c) {
writeBlock(gMotionModal.format(1), x, y, z, a, b, c, f);
} else if (f) {
} else {
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
return;
var start = getCurrentPosition();
if (isFullCircle()) {
if (properties.useRadius || isHelical()) { // radius mode does not support full arcs
linearize(tolerance);
return;
switch (getCircularPlane()) {
case PLANE_XY:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), feedOutput.format(feed));
break;
case PLANE_ZX:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
break;
case PLANE_YZ:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
break;
default:
} else if (!properties.useRadius) {
case PLANE_XY:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format
, zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), feedOutput.format(feed));
break;
case PLANE_ZX:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format
, zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
break;
case PLANE_YZ:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format
, zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
break;
default:
} else { // use radius mode
var r = getCircularRadius();
if (toDeg(getCircularSweep()) > (180 + 1e-9)) {
r = -r; // allow up to <360 deg arcs
case PLANE_XY:
writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format
, zOutput.format(z), "R" + rFormat.format(r), feedOutput.format(feed));
break;
case PLANE_ZX:
writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format
break;
case PLANE_YZ:
writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format
break;
default:
var mapCommand = {
COMMAND_STOP:0,
COMMAND_OPTIONAL_STOP:1,
COMMAND_END:2,
COMMAND_SPINDLE_CLOCKWISE:3,
COMMAND_SPINDLE_COUNTERCLOCKWISE:4,
COMMAND_STOP_SPINDLE:5,
COMMAND_ORIENTATE_SPINDLE:19,
COMMAND_LOAD_TOOL:6,
COMMAND_COOLANT_ON:8,
COMMAND_COOLANT_OFF:9
function onCommand(command) {
switch (command) {
case COMMAND_START_SPINDLE:
onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
return;
case COMMAND_LOCK_MULTI_AXIS:
return;
case COMMAND_UNLOCK_MULTI_AXIS:
return;
case COMMAND_BREAK_CONTROL:
return;
case COMMAND_TOOL_MEASURE:
return;
var stringId = getCommandStringId(command);
var mcode = mapCommand[stringId];
if (mcode != undefined) {
writeBlock(mFormat.format(mcode));
} else {
onUnsupportedCommand(command);
function onSectionEnd() {
forceAny();
function onClose() {
onCommand(COMMAND_COOLANT_OFF);
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(0)); // retract
zOutput.reset();
setWorkPlane(new Vector(0, 0, 0)); // reset working plane
if (!machineConfiguration.hasHomePositionX() && !machineConfiguration.hasHomePositionY()) {
// 90/91 mode is don't care
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0)); // return to home
} else {
var homeX;
if (machineConfiguration.hasHomePositionX()) {
homeX = "X" + xyzFormat.format(machineConfiguration.getHomePositionX());
var homeY;
if (machineConfiguration.hasHomePositionY()) {
homeY = "Y" + xyzFormat.format(machineConfiguration.getHomePositionY());
writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), homeX, homeY);
onImpliedCommand(COMMAND_END);
onImpliedCommand(COMMAND_STOP_SPINDLE);
writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
writeln("%");
