Do you mean a printed on paper 2D drawing with dimensional annotations and other manufacturing information? This is what most machinists think when they hear "print."
Or a 3D CAD file that provides the machinist with a representation of the object that they can import into a CAM program? You mention importing into CAM, this usually means importing a 3D CAD file, as a "print" cannot be directly imported.
If it's something to be bent with limited machining then 2D is probably OK. Anything more complicated these days is best sent as both a CAD model and a drawing with key features highlighted.
And now for the backseat driving: Can you bend 7075? And if so this might be something you want to send to a specialist bending shop? I guess it's only 15 degrees. As for machining it first, is 7mm critical? Why not make it out of 5/16" nominal rod which is about 8mm. That will save a lot of work. Or if it could be square in profile just mill or waterjet it from bar. The choice of solid 7075 is a bit strange in that you are going for a high performance alloy for a strut, which suggests something aeronautical or similar, but if you wanted it to be really light you'd want to go with a tube, even a 4130 tube as it would be easier to prototype. Or CNC the two 2" long end pieces that jog back and glue them to a section of carbon fiber tube in the middle.
Solidworks, Fusion 360 or OnShape would all be fine. I must assume that this is part of a larger project though so don't you have to have a lot more CAD drawings?
My rule for 7075, and this is in no way scientific, is that if you think you need it over 6061-T6 you are into a realm where you should have calculations to show this is the case. 6061 and 7075 have similar elastic modulii at about 10,000 ksi so stiffness will be the same, and even at a yield strength of 35,000psi a 7mm 6061 bar will yield at over 2000 lbs. So you could go lighter with tubing, but cracking might be an issue when you bend it. 2024 is also an option as its UTS is in between the other two. Various bike parts get machined from it like stems. 4130 is Chromoly steel and has a high Young's modulus albeit at 3x the density. But I bet you'll be able to do something clever with tubing there and get great stiffness if that's a consideration. Do give thought to relaxing your 7mm constraint to allow for 5/16" (7.9mm) though, Or even 3/8" (9.35mm) as then you can get .065" wall 2024 tubing which would yield at 2,850 lbs. I see on McMaster you can't get rod or tube in 7mm so you'd have to turn it down which is not totally trivial as the part is long and thin.
Notice
