Solid Edge
Results 1 to 19 of 19
Thread: Solid Edge
    Nov 2010
    UNITED KINGDOM
    58
    13
    8
    Default Solid Edge
    I am thinking about moving my personal work to Solid Edge, not really happy with the direction Fusion is taking and don't have access to SolidWorks anymore. They do a Student version that they also give to makers that comes with a permanent licence so I'm thinking about making the jump, but.... this has to be quite a long term thing, I am fed up learning where the buttons are in different CAD programs.
    I'm now pretty familiar with NX ( but can't get a second licence for home use ) so I know the synchronous modelling will come in useful, but can you use it as a normal history based parametric CAD program like NX ?
    Has anyone got anything good or bad to say about it ?
    I am going to be doing simple parts for cameras that I design but I like to model in assemblies and use master sketches and variables for driving my designs to make it easier to model a whole product.
    I will be doing lots of woodwork drawings, a bit of sheet metal, some parts for 3D printing and a few machined parts - mostly manually turned but probably the occasional 3+2 part too.
    Mar 2013
    Oregon
    1,815
    741
    2128
    Quote Originally Posted by alexdobbie View Post
    A basic CAD seat of NX, at least the one that comes with the NX CAD/CAM bundle package, is actually very powerful and reasonably priced. Once you get use to NX CAD, everything else is quite meh...
    Synchronous in Solid Edge is a totally different ballgame from Synchronous in NX. The tools and underlying architecture are identical, but Synchronous features in NX are just that - features. In Solid Edge, Synchronous is more of a task environment, and the changes aren't parametric. You enter SE Synchronous, do multiple operations, and exit out of the task environment with only a single feature in the tree that you can't really manipulate. The SE implementation is great if you are importing geometry and need to modify it, but it is nowhere near the kick-ass version of the tool you find in NX, where it really is a full-citizen set of parametric/feature tree operations you can use feely.
    Nov 2010
    UNITED KINGDOM
    58
    13
    8
    Quote Originally Posted by gkoenig View Post
    I know, that's what is worrying me a bit - can I go back to potatoes after the salmon ? It's just painful dealing with the UK VAR who doesn't seem interested in dealing with anyone who isn't Rolls Royce or Nissan. It's the one thing that might keep my using Fusion, I can actually get information about the product even if it makes me nervous!
    NX Cloud Connected feels like a move in the right direction but they're just so slow at getting it all together.
    That's a pity, synchronous in NX is the only way that makes any sense, I've tried most of the other direct editing features in CAD and only used them for fixing shitty imported geometery. I think I'll need to have a play around with the Solid Edge trial, I was hoping it was more NX-lite than it seems to be.
    Thanks for your insight, very useful!
    May 2002
    South Central PA
    13,549
    2237
    3476
    The short answer is yes. However it's been a long time since I've seen NX so I can't directly compare. SE has a normal history tree in Ordered mode. You can work only in ordered if you wish, or only in Synchronous, or switch between the two as needed. Synchronous features are all at the top of the tree, ordered features are all below. So if you create a part in synchronous, then add ordered features, going back into synchronous makes the ordered features unavailable to edit until you leave synchronous and go back to ordered, that's my only complaint. I usually start a part in synchronous then add some details in ordered, depends on which way is better suited to the feature. Switching between modes is just a right click selection.
    Short version - It's the only software I own that I actually look forward to using. If you found SW tolerable you'll love SE.
    I use it weekly, not daily, so I'm not a power user and not a wiz. The frustration I experience is how the improvements in each upgrade sometimes become hidden, sometimes something that was an icon on a toolbar gets developed into a toolbar of it's own so I have to figure out where that toolbar is, that sort of thing. I guess that's the nature of progress though, eh? I just figured out I called tech support 3 times so far this year, that's a lot for me w/SE.
    Have you used it recently? Synchronous allows you to put dimensions on features and edit the feature by changing the dimension, either editing the number or rolling the mouse wheel, etc. You can turn features on and off, like hole patterns and chamfers. The steering wheel and related tools are really powerful. Early on it was as you describe and I didn't like it, I find it a lot more capable now.
    Nov 2010
    UNITED KINGDOM
    58
    13
    8
    Quote Originally Posted by Mud View Post
    That sounds like something I can live with, I'm just waiting for my non-commercial licence to be sorted out and then I'll report back here how close it is to NX. I don't even need it to be that close, just the usual history based 3D modelling tools would be fine. The synchronous stuff is useful in NX but I don't use it that often, only if I want to make a small change without blowing up the history tree late in the project.
    I hope it will be as enjoyable for me! I found the assembly tools very frustrating in Fusion and it looks like Solid Edge uses the more usual constraining freedom rather than allowing it. Have you done much assembly work or top down modelling ? Does it work well ?
    May 2002
    South Central PA
    13,549
    2237
    3476
    Yes, almost everything goes into an assembly. Assembly tools work well. and creating a part in the context of an assembly using the geometry of other parts is very handy. One neat thing in Synchronous is called Live Section - It's like having a 2d crosssection view right in part or assembly so you don't have to change environments to inspect what you are creating. Do other CAD programs do that?
    Nov 2010
    UNITED KINGDOM
    58
    13
    8
    Excellent, I suspected that it would be easy to work that way but I have been surprised before!
    I can do that in NX and only section some parts of the model so I can see into an interior housing but still reference some parts if I want to, it's very useful. I wasn't as proficient at CAD when I was using SolidWorks so I never tired it there and I haven't found a way in Fusion, and hopefully won't have to
    Thanks for your insight, I'm looking forward to playing with Solid Edge.
  8. Likes Mud liked this post
  9. #8
    Sep 2010
    Oklahoma City, OK
    4,325
    748
    1800
    Like how much? Need 3 axis milling and plasma.
  10. #9
    Mar 2013
    Oregon
    1,815
    741
    2128
    Quote Originally Posted by Cole2534 View Post
    ~$15k for CAD+CAM.
    I am sure you can probably program the Plasma with the 2D toolset.
  11. #10
    May 2002
    South Central PA
    13,549
    2237
    3476
    How much is maintenance at that level?
  12. #11
    Nov 2010
    UNITED KINGDOM
    58
    13
    8
    Maintenance is pretty much 20% for every package in the UK, so about 3k a year.
  13. #12
    Dec 2011
    England
    118
    71
    49
    Who are you dealing with? there's more than one VAR
  14. #13
    Nov 2010
    UNITED KINGDOM
    58
    13
    8
    Quote Originally Posted by xlr8tr View Post
    It turns out I was talking directly to Siemens ( I didn't realise )and that was why there was a lack of interest! OnePLM got in touch on LinkedIn and they have been pretty good - so mea culpa on that one, is there a preferred VAR in the UK for machining knowledge ? I thought they had all morphed into one ( I thought there was only MajentaPLM and someone else ) but my google-fu wasn't working and there are quite a few (something you clearly already know )
  15. #14
    Jun 2019
    303
    92
    250
    Yea it's a problem with NX. They truly only cater to the whales. The changes they make in their releases plus the priority they put on what to update shows who they cater to. I know right now on their forums there is a bit of a row going on because in the latest release they removed trochoidal milling and their only response is to use adaptive milling even though it does not work for everyone's application.
    We are sticking with 12 for now because we are afraid of moving forward because we make extensive use of point-to-point drilling, which is in 11/12 only hidden, but still usable. Their newer hole-making operation does not give the full control we need for most of our parts nor does it properly work with some of our geometry.
  16. #15
    Oct 2017
    FINLAND
    556
    89
    170
    I was looking for a thread like this. I am a Fusion 360 user, coming from sketchup and a decade before that I played around with 3Ds Max 2.5 and also an earlier version of blender.
    I have gotten used to F360, because it is free and I am a hobbyist, and I like the way things are done there now, but I am also worried about them "altering the deal" and don't like to be too dependent on a single CAD program so I am now looking at Solid Edge 2020, downloaded the free student version this weekend.
    So far I am finding it pretty hard to get into, I tried switching off the synchronous mode because I am really used to having a F360 like timeline, but I don't seem to have that in any case and I wasn't able to extrude a simple shape even in that mode. I asked on the siemens forum becaue of profiles not being connected, and sure if I do some extra steps I can get it to work like planned. But I feel I shouldn't need to do those extra steps in the first place, the software should be smart enough to work like that anyway, which it seems to be in synchronous mode though, the exact same procedure works there without extra steps.
    It seems SE is really pushing this synchronous feature and most tutorials are based around it so I guess if I want to learn it, I better learn to like synchronous mode...
  17. #16
    Mar 2013
    Oregon
    1,815
    741
    2128
    Quote Originally Posted by DennisCA View Post
    The SolidEdge paradigm of weird modal workspaces is kinda frustrating. Especially because NX exists as irrefutable proof that all of that bullshit is 100% unnecessary. The best thing about SolidEdge is that Siemens owns them and can stuff some amazing tech (like Synchronous) into a mid-tier CAD package. The worst thing about SolidEdge is that Siemens owns them, and will always kneecap those awesome technologies (like Synchronous) to protect NX.
    Similar to how SolidWorks will never get true class-A surfacing tools because DSS needs to do everything they can to protect all the revenue they get keeping the auto/aero industries held hostage by CATIA.
    Eventually, this house of cards will crash as CAD becomes a commodity. Fusion/OnShape are maturing faster than the legacy gear can offer innovative features to keep buyers paying through the nose for meager yearly maintenance. All the real growth is figuring out the PLM/data management side of the equation, and these guys are gonna wonder why they are paying for 2 CAD teams (each), running 2 separate CAD brands (each). Inventor goes first, once Fusion is feature complete against it. As that happens, SolidWorks will go subscription only and spend 3 years doing The Adobe Transition, probably buying MasterCAM along the way. PTC will roll Creo and OnShape together and focus on Windchill as the future. Siemens will sunset SolidEdge and move NX's price points down and onto subscription so they can focus on maintaining Teamcenter's dominant position as the PLM system used by 80% of the F500.
  18. Likes CNC Hacker liked this post
  19. #17
    Oct 2017
    FINLAND
    556
    89
    170
    A dark future, real tired of subscription software...
  20. #18
    Apr 2018
    UNITED KINGDOM
    2,211
    1012
    ^^ Sad. One ring to rule them all, I guess
  21. #19
    Nov 2014
    Colorado
    2,848
    3366
    784
    I used to run various older versions of Solid Edge and found it very intuitive and well designed and had substantially fewer set-ups and menus and mouse clicks than Solid Works (for example)…
    I'm surprised the SE 2020 version seems obstructive to a more natural workflow.
    There were many features in SE going back to Intergraph days (before Siemens PLM bought them that were really good/ advanced ) and worked more like professional graphics software like Maya, 3d studio max etc. (and even Soft Image (back in the day)).
    Admittedly the versions I have used were before any subscription model.
    Perhaps there are older tutorials you can dig into ?
    I thought some of the newer inclusion of the sexier NX modeling capabilities was supposed to be a nice addition to SE ?
