Solidcam G41 cutter radius compensation
Results 1 to 11 of 11
    Jul 2017
    SLOVENIA
    41
    Default Solidcam G41 cutter radius compensation
    Good day, can someone explain why I cant get cutter radius compensation for roughing? The Gcode outputs G41 just for finishing pass although I checked both checkboxes for roughing and finishing toolpath on open pocket operation. Do I need to make some changes in VMID file or postprocessor? Thank you.
    Mar 2016
    Illinois
    516
    88
    271
    Quote Originally Posted by Mlinka View Post
    Why would you use radius comp on roughing? In most cases you have an offset option to leave stock for finishing.
  3. Likes Billetgrip liked this post
    Jun 2006
    Near Seattle
    5,067
    3603
    1481
    Are you sure you have "use compensation" turned on in the operation?
    Jul 2017
    SLOVENIA
    41
    Quote Originally Posted by Shawnrs View Post
    Hy, I noticed if I dont use machine cutter radius offset and use software cutter radius offset I got very jerky moves on splines. I noticed if I use machine cutter radius compensation G41 the movement is smooth. The control is sinumerik 810M.
    Jul 2017
    SLOVENIA
    41
    Quote Originally Posted by bryan_machine View Post
    Under Technology tab i checket both Compensation of Rough passes and Compensation of Finish passes.
    Although when I check the Wall checkbox under finish Compensation of Rough passes gets gray.
    Mar 2016
    Illinois
    516
    88
    271
    For roughing it won't be smooth but you do have a clean up pass option to smoothing out edges. I have always used roughing to hog out material and leave some for the finish milling.
  8. Likes Billetgrip liked this post
  9. #7
    Jul 2017
    SLOVENIA
    41
    I doesnt workout for me because jerk can brake small endmill diameters: 1mm-2mm.
  10. #8
    Mar 2016
    Illinois
    516
    88
    271
    have you tried using different patterns for pocketing? Pocket in or pocket out may work better for you. Also there is a high speed machining tab you can check. Volumil is an option for high speed machining but I am not sure if you have that option.
  11. #9
    Jun 2014
    Singapore
    39
    What happens when you open a pocket operation and don’t choose the geometry go directly to the technology, and repeat the actions you have done before
  12. #10
    Jul 2017
    SLOVENIA
    41
    Hy, there is still jerky motion problem. Tryed all kinds of patterns. High speed machining makes a code very long and Im limited with memory on my machine. Still didnt figure out how to set DNC.
  13. #11
    Jun 2006
    Near Seattle
    5,067
    3603
    1481
    Mlinka - are you using iMachining, or a conventional pocketing operation? (I've never heard of volumill in conjuction with solidcam - but iMachining is their solution for that part of the market.)
    You are turning on the "compensation" option, right?
    I don't know why you are getting jerky motion....
