SolidCam problem
Nefelin
Jan 5, 2022
Hello! I would like to use your help. I have got problem with milling cutter compensation in profile operation. There is always half of cutter diameter compensation in generated G code when I am using left or right compensation/G41,G42. Turn on and off compensations in Technology tab makes no difference. I tried to edit post processor but I cant solve this. Can anybody give me some advice?? Thank you very much.
When you have the toolpath right click the op and in the NC tab there is a CNC compensation. See if you get the results you need with it on or off.
