SolidWorks CAM Minor Issue
Likes Likes:  0
Results 1 to 4 of 4
    Jan 2020
    Florida
    6
    Default SolidWorks CAM Minor Issue
    Hello,
    I am designing a connection for a school project on SolidWorks to use on a HAAS CNC mill. I have figured out the process for the most part, however, during the simulation of the operation, there is a bit of my stock left behind.
    As you can see, in the neck of the piece.
    In order to make the neck I am using a 0.78" diameter keyway cutter with a width of 0.25". The toolpath generated by the software contains only one loop, so it only takes 0.25" of stock off the 0.30" neck, leaving 0.05" behind. I have been trying to figure out how to make it such that the tool does a second loop to remove the remaining 0.05" but so far nothing. Anyone have any tips?
    May 2014
    Los Angeles
    446
    82
    Somewhere there should be a machine at multiple depths option. Or draw another sketch .05 higher and copy the operation to that. Not sure about solidworks cam as I use hsm but it should be there.
    Nov 2014
    Florida
    4,125
    1619
    1935
    Quote Originally Posted by maikol2346 View Post
    Hello,
    So the undercut is .300" wide? If that is true, you *should be able to tell it to do a depth cut of 1 at .050", or a finish pass on the depth at .050". But, depending on the material of the workpiece, and your setup, the machine may not like taking a 1/4" wide keycutter to full depth (radially on your part) in one pass. If your setup is good and solid, maybe.
    *not familiar with solidworks cam, not sure what your parameters are labeled as far as lead in / lead out, depth cuts, multiple passes, etc....
    Jan 2020
    Florida
    6
    Thank you very much. Turns out I wasn't using the correct strategy and I wasn't defining my part properly.
